Lack of Power
Lack of Power
I have owned my 1988 f250 351 4x4 for about six months. It was lacking power so I replaced the rotor, cap, plugs and wires as a first line of action. (I had to use 4wd in low range to haul a load of wood out on forest roads). The tune-up gave me a little more power but there is still a definate problem. From a stop when I press down hard on the accelerator the engine increases in rpm only marginally and there is very little power at the wheels. I have nearly as much power slowly pushing the throttle as I do when I floor it from a stop. At higher speeds it seems to react better. Any ideas of the culprit? Maybe injectors, tranny? I cleaned the k&n filter with no change in behavior.
Thanks in advance for the input
you can also unbolt the Y pipe from the manifold , it will be loud but you will notice improvement right away. I would also check codes www.fordfuelinjection.com will tell you how. what size tires are you running and what gears are in the truck. I imagine the tranny is a C6 correct? whats the fluid smell/look like and when was it serviced last?
thanks for the input guys
I will check the cat and did buy a fuel filter to replace the old one. The wires are all properly ordered and connected. Although I have not put a light to the timing issue. I appreciate the input. I am glad no one seems to think the tranny is an issue as that was the most expensive culprit. Again thank you for the suggestions.---btw no cel but will pull codes anyway.
