master cylinder question
Old Sep 27, 2006 | 07:05 AM
Fritolay's Avatar
Fritolay
my old truck 72 f100 4x4 has gone to leaking brake fluid all from the rear of the master (front brakes) all over the inside of my cab. i just this past weekend went and picked up several pieces of a 79 f150 to include the entire front axle master cylinder vacume boost thing proportioning valve and all front brake lines. my question is what do i have to modify to use the vacume boost or should i just use the new master and proportioning valve? my truck is manual everything. thanks in advance for any help.
Old Sep 27, 2006 | 08:52 AM
390fe's Avatar
390fe
I think all you need to add for power brakes would be the booster and proportioning valve. I'm pretty sure you've got everything you need.
Old Sep 27, 2006 | 09:31 AM
limegoldf100's Avatar
limegoldf100
If you stay with drum brakes, you shouldn't need the proportioning valve.
Old Sep 27, 2006 | 03:37 PM
beedevil1973's Avatar
beedevil1973
to use the vaccum bost you just need to find a place on the intake that creates vaccum and run a line from that point to your booster
Old Sep 27, 2006 | 06:32 PM
Ford_Six's Avatar
Ford_Six
Proportioning valve, booster, master (since your is bad anyways), and I would replace the steel and rubber lines. You also need the tabs that bolt to the frame at the front to hold the rubber lines to the calipers. Since you are significantly increasing the pressure in the brake system, I would also replace the steel and rubber lines at the rear, to prevent blowing one of those out.
I have heard, and cannot confirm it right yet, but the pedal assembly pivot point was different for manual and power brakes, so your brakes might be a bit on the touchy side.
alchemist1
Oct 2, 2012 09:31 AM
crazy96863
18
May 7, 2012 11:55 PM
66_in_ky
Dec 16, 2008 05:22 AM
phoneman91
Apr 21, 2005 01:49 AM
prairiedellss
Sep 16, 2002 11:48 AM
