'Factory' location of proportioning valve?
OK, I'm asking this, just to make sure someone before me didn't change something on my 74 F-100. On that truck (the 74 F-100 2WD LB), it has manual brakes and also has disc brakes on front. The proportioning valve on the truck is located just below and slightly in front of the master cylinder. Is that where it is supposed to be?
On my 77 F-150, the proportioning valve is located quite a ways down under the master cylinder, close to the ground.
I got up with InLine tube today. Here's the deal. According to them, on most 74's, the brake proportioning valve is slung up under the truck. On a few, the valve is located just under the master cylinder. That's the way mine is. They have the correct pattern and will be sending it out shortly. As for the fuel line that isn't quite right, I'm going to try to dry fit the rear piece even though it isn't a match for the original, to see if it would still work - it might...
Otherwise, InLine wants me to send them my old fuel line to them so they can build me a new one.
brake line connection
"I was talking to a guy at premier rubber here in Portland when I was buying some replacement fuel line. I was replacing the rubber hoses on my tank switching unit, because they were looking really old and brittle.
He told me that the rubbers need to be replaced regularly, due to the alcohol in the ethanol eating through them after time. I still have some left and plan to replace all the rubber fuel line with new stuff to prevent stuff like this."
Hi Mike I was looking at your pics with inline the other day and saw the rubber line connecting front and rear fuel line,and was going to ask about todays fuel and that set up,then i read this post,and wanted to get your thoughts on it.Is this what inline recomends? "SAE J30 R9 is the spec you need. R6 is not ethanol resistant." Looks like another member answered that readily.
From the way I read the SAE J30 spec., all J30 hose meet the same specs when it comes to ethanol fuel degradation. The "R" part has more to do with pressure, R6 is okay for carbs not fuel injection. R9 is for fuel injection.
If I'm wrong, someone correct me.
Personally I would use the R9 simply because it's built to withstand higher pressure.
joditruck
08-13-2007 06:39 AM
tbspks
09-02-2006 01:03 PM
