You may have a bad ground. Make sure the grounds are clean.
I have seen cars with the ground wire not hooked up burn a hole in a hot wire to create a ground.
Did you see smoke from any wire(s)?
I have cleaned where the ground connects to the engine. When I try to start with the key or jumping the solenoid, the solenoid just clicks.
Since you just replaced the solenoid, either a bad battery or a bad connection. Your voltage regulator could have screwed up and started overcharging which would heat things up quickly and wouldn't take long to short out a battery if gone unnoticed.
Hey everyone,
I got it fixed.....it was the starter. I tried a starter from a truck that I knew worked and it did the same as the first one, so that stumped, finally had the starter tested and it showed good.....brought it home and didn't work, bought a new one and worked good.....go figure. Thanks for all the help.
Yeah, I had a starter go bad and I about tore the truck apart trying to find the problem.
That bad starter checked out good also.
The truck supposidely had a fairley new starter on it from Autozone when I bought it.
I replaced it with a NAPA.
I had about the same thing happen but I tested the starter at an auto shop that put in under a load. Auto Zone's tester didn't load the starter. The starter tested good so I replaced the solinoid and cleaned the cable connections and it's starts everytime now.
