battery drain
Old Aug 19, 2006 | 09:41 PM
hotshot414c's Avatar
hotshot414c
Question battery drain
I have an 85 f150 4x4 . if i dont disconnect the battery every night it will be dead by morning. I ve changed the alternator and voltage regulator. with the battery disconnected and checking the draw with a meter ive got a 12 volt draw. i went through and pulled evey fuse while watching the meter and was unable to find the problem. any body have any idea what else to check ??
Old Aug 19, 2006 | 09:56 PM
Mil1ion's Avatar
Mil1ion
Try dis-connecting the voltage regulator & alternator harness over night.
VR's are known to draw current....as well as fuse boxes on the back of them.
How much draw in amps is happening ?
Old Oct 3, 2006 | 08:13 AM
tomclifford1's Avatar
tomclifford1
Hijacking this thread--but my 84 is doing the same--I get a reading od 12+ volts when I test the ground cable to Neg post on battery--Unplugging all fuses doesn't stop drain--Unplugging the regulator harness makes it stop--I have replaced the regulator but it still did it--I'm wondering if, when the alternator got replaced the wiring got on wrong--Does anyone know what colors go to what terminal?
thanks alot--love the forum
Old Oct 3, 2006 | 08:32 AM
tomclifford1
found color/wiring chart--all seems to be well with the wiring--Now what--a bad regulator maybe??
Old Oct 3, 2006 | 08:33 AM
Sport45's Avatar
Sport45
As Mil1ion implied, testing voltage doesn't really tell us anything about the drain other that that it exists (as it probably should to some degree, for clocks, radio presets, etc.). What is helpful is to know the current drain. Use your VOM on the "amps" scale and check the milliamp drain from the ground cable to the battery post. Make sure the ignition is off, doors are shut, and the underhood light (if equipped) is unplugged for this test.
Old Oct 3, 2006 | 01:10 PM
tomclifford1
my amp drain is 2.65--2.76 amps---pretty big drain--can't figure this one out--
Old Oct 3, 2006 | 02:21 PM
Sport45's Avatar
Sport45
That is a lot. Try pulling fuses one at a time while the ammeter is hooked up. If nothing changes you may have a bad diode in your alternator.
Old Oct 3, 2006 | 03:11 PM
tomclifford1
--tried that--the only thing that stops the amp drain is unplugging the v/r--I've replaced both the alt and reg twice now---go figure
Old Oct 3, 2006 | 03:55 PM
Piffery1's Avatar
Piffery1
Make sure the Orange/Light Blue (O/LB) wire goes from the field (F) terminal of the regulator directly to the field (F) terminal of the alternator. Does the alternator charge the battery at 14 to 16 Volts? With Ignition Switch "OFF" make sure there is no voltage on the stator (S) terminal of the regulator. If there is voltage, find where it's coming from. There may be voltage on one or more of the Ignition Switch "RUN" terminals with Ignition Switch in the "OFF" position due a faulty or misadjusted switch.
