big 3 upgrade
Old Sep 25, 2006 | 07:01 PM
ReAX's Avatar
ReAX
big 3 upgrade
How many Amps should a 1/0 guage wire be fused for? I ordered 250 amp ANL fuses/holders because my alt is rated for 220 amp and I wanted 10% for surge. I found online that 1/0 should only handle 130 amps continous. Anyone on here have any expirience with this type of upgrade?
Old Sep 25, 2006 | 10:00 PM
Franklin2's Avatar
Franklin2
I am going by the NEC electrical code book for electrical work in residential and commercial wiring. It is a lot more conservative than the wiring specs they use for vehicles, so it should give you plenty of headroom.
They list a 1/0 copper conductor wire with 194 degree rated insulation in free air by itself is rated for 260 amps.
If the same wire is in a cable with other wires, it is rated at 170 amps.
Old Sep 26, 2006 | 08:26 PM
ReAX's Avatar
ReAX
260 amps for what lenght? I can't find any higher than 205 amps, but 250 should work I guess.
Old Sep 27, 2006 | 12:01 AM
Franklin2's Avatar
Franklin2
You can run any length with that many amps. They are not taking into consideration voltage drop, which is what you would be concerned with for length.
Unless you are going to run the cable all the way to th rear of the vehicle, I do not think length will become a factor.
I do not know what you intend to run with this alternator, but I doubt you will ever use it's full output. You will never get full output anyway unless you run the engine rpms way up. And don't forget the battery is in the system too, so it will always take up some of the slack if the voltage in the system drops to around 12.
Old Sep 27, 2006 | 08:09 PM
ReAX's Avatar
ReAX
Well the charge wire is done and the 220 amp alt is in. I have a 250 amp fuse inline, but I couldn't connect the stock charge wire yet.
I made a PDF of my install, I am quite pleased with it and will post pictures hopefully tomorrow.
http://home.cfl.rr.com/reax/alt.pdf
Old Sep 28, 2006 | 08:45 PM
ReAX's Avatar
ReAX
I didn't get pictures cause the battery was dead again. So a new optima will be in monday, good news is I am stuck at home all weekend so I'll be able to finish the grounds and maybe even make a set of jumper cables from hell, 1/0 aught to start a motor quick.
Old Sep 29, 2006 | 05:12 PM
ReAX's Avatar
ReAX
The alternator is not charging. I think the problem was carried over from the old one as well. While idling the battery has 11.93v, batt to alt housing 11.89, charging fuse to batt 11.89. Engine off batt has 12.18v. It looks like I will be tracing wires this weekend. Any know of common issues with 2002 F250 SD with 5.4l?
Old Sep 30, 2006 | 03:06 PM
ReAX's Avatar
ReAX
Charge wire
finished
Last edited by ReAX; Sep 30, 2006 at 03:08 PM. Reason: I did put the belt back on before testing.
akblackfoot
Jan 6, 2017 11:36 AM
04superduty6.0
Apr 17, 2016 07:45 PM
mattymax
Jan 7, 2016 10:50 AM
Rusty_S
Electrical Systems/Wiring
Feb 20, 2014 08:36 PM
buck20
Dec 17, 2007 12:33 AM
