I know it made his hotrod truck run as smooth as silk.
Brought my cylinder contribtion imbalaces down by about 36% according to the IDS at work on cylinder contribution/balance test.
There is actually a main external balancer, and a free-floating balancer inside of it which rides on the layer of silicone....the silicone transfers the harmonic vibrations to the inner balance ring, but does so in a slow a, for lack of better terms, "metered" manner, as to absorb as much as possible in the process.
I do know it has been keeping the bottom end and bearings together in engine number 6 here under some pretty heavy revs (revs that had previously been pounding connecting rod bearings severly) and reduced alot of wear, judging by the last teardown. Lifters still arent living though Ask npccpartsman about that, we still cant get the busted number 1 exhaust lifter out of my crankcase.
I can tell you that when I heard Gene's Red Racer Truck and saw the motor I was amazed. It is so smooooooth. Money worth spending.
Yes, very much so. I can certainly assure you that even stock, 2 identical engines side by side, one with the damper and one without- the one with would have a significantly less amount of bearing and piston skirt wear at 100,000 miles than the one without. Simple fact of the matter is that engine imbalance and vibration is destructive, and a Fluidampr helps to alleviate it.
Now that makes it worth the cost and install right there. Thanks for the information Matt.
does anyone know how much for the fluid damper and how much to install it?
300-400 for the Fluidampr depending on where you get it. Not sure about the install, its not a horribly bad install if you want to do it yourself, but you would be well invested to buy a fan wrench before doing so to simplify your job. You can get the 2-peice fan wrench set (which is far better than Ford's POS they get 90 dollars for) from KD tools for 30 dollars.
All thats required is removing the fan shround, fan and fan stator, and belt. Simply unbolt the damper (they are TTY bolts so you'll need to replace the bolts, can get them through Ford) and bolt the new one on.
bottom line would it be worth putting one on a stock 2004 f250 6.0l with exception of afe stage 2 intake, and edge platinum. talked to a mechanic who only knows of drag racers using them, or someone with motor work. so is itworth it stock?
bottom line would it be worth putting one on a stock 2004 f250 6.0l with exception of afe stage 2 intake, and edge platinum. talked to a mechanic who only knows of drag racers using them, or someone with motor work. so is itworth it stock?if it was that good would everyone have one?
I have installed dozens of Fluidampers on small and big block Chevrolets over the years, I really have had good luck with them. Comparing bearing wear on similar engines with elastomer balancers, bearings look like they have double the miles on them. I installed my 6.0 Fluidamper when I had the cab off for the headgaskets and studs, so installation was quite easy. I would recommend a Fluidamper for every 6.0 out there, even deadstock commuters/grocery getters.
