Sponsored by: Auxito
Need part name or # for Shift indicator problem
Old Sep 25, 2006 | 05:48 AM
tealboy1's Avatar
tealboy1
I posted previously about the shifter indicator having broken. Park is in the R position, Reverse is in the N position and so on. I called Ford parts and they did not know what i was talking about.
Can you provide more information with regard to a description of the parts i need to fix this, or a part number. anything that i can offer the parts guy to help figure out what i need to fix this issue.
thx
Old Sep 25, 2006 | 07:20 AM
mel2000f150's Avatar
mel2000f150
I have the same problem. can anybody help?
Old Sep 25, 2006 | 09:27 AM
7700Rob's Avatar
7700Rob
thx
You may want to try another dealer, or a more experienced person at your local dealer. If you're lucky, maybe the service dept. would let you talk to a tech.
However, I'm not sure, but I think the indicator is controlled by a small wire that's visible under the dash. You may be able to correct this yourself.
Old Sep 25, 2006 | 08:03 PM
ncranchero's Avatar
ncranchero
I can't give you the whole part number for the 2001 model but tell the parts person you're looking for the shift indicator, base part number 7A110 .
Old Sep 25, 2006 | 08:04 PM
jamrock's Avatar
jamrock
I had a similar problem with my 99 F150, I removed the cowling around the steering wheel, to pull out the dashboard. There is a little plastic adjuster/wheel, but be careful when adjusting it as it is easy to break.
Old Sep 25, 2006 | 08:21 PM
jrlowscot's Avatar
jrlowscot
Yeah it is easy to adjust, if nothing is broken. Use the search for other threads describing the process.
Old Sep 27, 2006 | 07:45 PM
tealboy1's Avatar
tealboy1
do you really need to pull the dashboard to adjust the shift indicator dial or can you get under it and locate it easy enough. This sounds like a big job for a simple adjustment.
__________________
BaitGuru
Jan 20, 2015 06:53 PM
terrylamar
Sep 10, 2014 04:24 PM
Evan_P
43
Aug 8, 2014 12:10 PM
sessland
Jun 16, 2014 09:10 PM
guitar4him
Mar 11, 2002 01:51 PM
