first head removel
Old Sep 24, 2006 | 09:49 PM
jbone 302's Avatar
jbone 302
first head removel
Broke off a headder bolt after pb and heat any tips to removing eads heads I have a 75 with a 360
Old Sep 24, 2006 | 10:11 PM
darrin1999's Avatar
darrin1999
make sure you keep the pushrods in their proper places, and the rest is pretty self-explanatory, you dont have to worry about misplacing rocker arms as the fe blocks have shaft mount rocker systems... thats about all ive got for you besides make sure you get good gaskets when you put it back together
Old Sep 24, 2006 | 10:25 PM
fellro86's Avatar
fellro86
If it is one of the top ones, like usual, I would see if you can't drill through it and just put a nut on the back... I did that with my last FE, and it worked out ok. Beats pulling the head for a stinking exhaust bolt...
Old Sep 25, 2006 | 10:03 AM
Mike G's Avatar
Mike G
A socket handle or chunk of wood can be used in an intake port to pry them loose. I also recall, on the intake side of the heads about 3 or so inches back, there being a notch or two where you can slide a wedge of some sort to pop them off.
--Mike
MER
21
Feb 2, 2008 04:02 PM
MisterCMK
General Automotive Discussion
Sep 25, 2007 09:28 AM
Chumbucket
Apr 11, 2006 07:53 AM
Dirt Head
Aug 27, 2004 07:29 PM
GendoIkari69
Feb 26, 2002 10:30 PM
