292 valave clearance
Old Feb 19, 2001 | 06:46 AM
rudy's Avatar
rudy
I want to do a valve job on the 292 in my 64' F600. Does anyone know what the valve clearance specs should be (intake & exhaust). Also, what is the head bolt torque sequence and the lifter assembly torque specs? Thanks
Old Feb 19, 2001 | 08:24 PM
glindley's Avatar
glindley
Rudy,
The valve lash spec is .019 Intake and exhaust. The head bolt Torque sequence (65-75 ft-lbs) is -
Top of Engine
---9 5 1 3 7---
-10 6 2 4 8-
By the lifter assembly, I am assuming that you mean the rocker shaft support-to-head bolts. If so, the torque spec is 12-15 ft lbs. Hope this helps..
Gene
Old Feb 19, 2001 | 11:13 PM
hpguy's Avatar
hpguy
Why don't you post this question in the Y-block forum?! There's guys there that know every torque spec for EVERY bolt/nut in that entire engine!
Just a reminder guys, we DO have a Y-block forum now! The last one failed, but I convinced Ken to give it another go; let's not see this one go the same way!
-Andrew
f250_64(No Email Addresses In Posts!), same for yahoo messenger
Nothing, and I mean nothing, stirs the soul, saying I'm a bad **** like lettin'em rip with a window shaking, fuel gulpin, carbon monoxide belchin, attention gettin, V-oh my LORD!-8!
Old Feb 19, 2001 | 11:16 PM
hpguy's Avatar
hpguy
halltm
Apr 13, 2011 10:25 PM
jjs64F100
Aug 13, 2010 02:20 PM
64F-100
Apr 16, 2009 06:20 AM
62dump
Jun 7, 2008 12:30 PM
fordy29264
Sep 14, 2004 12:00 AM
