Sponsored by: Auxito
Transmission problems
Old Sep 23, 2006 | 08:21 PM
randywd's Avatar
randywd
I have a 2000 f-150 5.4 triton. I had a new tranny put in last Nov. It is now shifting hard again. It will go up to 4000 rpms before it will shift. I am thinking it is possiably a sensor, but not sure. The fluids are clean and do not smell burnt.....any help would be appriciated.
Old Sep 23, 2006 | 10:47 PM
bosshoss's Avatar
bosshoss
I have seen the shift accumulater pistons stick. If that is what is going on you will need to remove the valve body in the transmission to make repairs. Have you needed to add transmission fluid to the transmission since the replacment? What type of oil did you use in the transmision? Might check to see if a warrenty is still good. Does the light on the gearshift lever flash? Have you had the truck scanned for codes yet. If all else fails, you might add some transmision oil-additive. Might also be a sticking solinoid as well. Not much help, but a few things to roll around. Good luck
Old Sep 24, 2006 | 04:13 PM
randywd's Avatar
randywd
thanks man, you have gave me some things to checck out... We have not had to add any fluids either, but thanks again
Old Sep 24, 2006 | 08:51 PM
wtesh's Avatar
wtesh
If you are having the same problem with a new trans that you had with the old one, does it not seem that the problem is not in the trans. I would suspect the truck computer, or a sensor feeding info to the computer. I agree a trip to Autozone for a code readout seems like a good idea.
Vegas Ernie
1983 - 2012 Ranger & B-Series
Apr 25, 2014 12:13 AM
66_in_ky
May 6, 2010 09:25 PM
EaTmYtAiLpIpEs
Dec 14, 2008 07:40 AM
custom_foam
Sep 7, 2001 02:58 AM
