Power steering
Old Sep 23, 2006 | 01:33 PM
Ryanabby's Avatar
Ryanabby
Power steering
I recently purchased a 1964 F 100/351W/c-4.I would like to install power steering.What is the easiest way to do this? Thanks for any response
Old Sep 23, 2006 | 02:20 PM
jowilker's Avatar
jowilker
Hi Ryan, Welcome to FTE the nations truck stop.
Maybe you can spend a little bit of time using the search feature for 64 power steering and come up with some ideas.
There are many Threads on the topic.
John
Old Sep 23, 2006 | 07:01 PM
User 71024's Avatar
User 71024
Narrow tires and lots of pressure.
Old Sep 23, 2006 | 10:03 PM
rusbukt's Avatar
rusbukt
I put power on my 65. Came off of a 66. If you can find a Bendix gear box. It should be a direct fit. Was on my 65. If you go to a later model truck you will have to modify steering column. Bendix boxes are hard to come by and expensive rebuilt. Need to replace crank pulley and get all correct brackets. I purchased gear box, pump,pulley and all mounting hardware. Took about two hours to install.
Old Sep 24, 2006 | 07:44 AM
banjopicker66's Avatar
banjopicker66
Careful. He said he has a '64. The '64 and earlier trucks look like the '65 and '66, but they are an entirely different animal underneath. Ford made a major model revision without making a body design change - and that throws the normal assumptions off.
Nothing but a few body parts interchange between the model types.
Since early '65s have been known to be titled as a '64, double check the front suspension. If your truck has a single I-beam for a front suspension, it is a '64, and you cannot use the later PS setup as a bolt on solution.
Old Sep 24, 2006 | 10:38 AM
1964FORD4ME's Avatar
1964FORD4ME
Great call bangopicker66...I was just going to say the same thing..... I have a 64 and plan on useing one of two ways... Toyota powersteering box for "1984 4x4" or the aerostar front suspension. I have not made up my mind yet waiting to see what kind of problems if any from the aerostar. Also Ericj is right narrow tires on the front is the easy quick way till you make up your mind what you want. Run a search get all the facts on this job then make up your mind
Have a great time
Jason
Old Sep 24, 2006 | 09:58 PM
drof46's Avatar
drof46
I'm still hoping for the aftermarket rack and pinion steering available for the pre 61 trucks.
Vinford
May 7, 2014 05:56 AM
beckman
Apr 17, 2013 11:54 PM
FESTUS65
Sep 29, 2011 02:51 AM
Kalve
General Automotive Discussion
Apr 23, 2010 10:36 PM
cburwell
Oct 23, 1999 03:46 PM
