Offroad & 4x4
identify this axle....
Old Sep 26, 2006 | 04:17 PM
bremen242's Avatar
bremen242
Originally Posted by mustange70
Marmon axles were alot lit the eaton axles with a removable carriers and what not (the older 50's conversion used this style of axle, they used huge ring gears but the axles weren't worth the effort) Odds are its a 70 low pinion axle as marmon didn't use there own rearends till you got into the heavier trucks.
I know they did use eaton axles sometimes.. but after much googling, I think I found the combination for the f-superduty. up to the late 80s, they used Dana 70 lps.. in early 90s, they started using a carrera axle (some kinda italian made axle).
Old Sep 27, 2006 | 06:43 PM
mustange70's Avatar
mustange70
ford trucks never came from the factory with d70's (only converted trucks did), they only trucks with factory d70's were the 1.5ton and heavy internations and dodges in the if i remember right late 60's and through the 70's and early 80's i think.
Old Sep 27, 2006 | 09:44 PM
bremen242's Avatar
bremen242
yes.. I meant marmon used the Dana 70s.
Old Sep 28, 2006 | 08:07 AM
LedheadELH's Avatar
LedheadELH
so Ford never used the Dana 70 up front, and is it a 1 1/2 or a 5/4 rated axle?
Old Sep 28, 2006 | 05:20 PM
mustange70's Avatar
mustange70
yep you got it
Old Sep 28, 2006 | 08:46 PM
LedheadELH's Avatar
LedheadELH
so is it a 5/4 ton or is it a 1 1/2 ton?
Old Sep 28, 2006 | 09:21 PM
bremen242's Avatar
bremen242
probably a 1-1/4. F-superdutys are F450's now..
Old Sep 29, 2006 | 09:03 AM
LedheadELH's Avatar
LedheadELH
okay, that's what I thought it was, but wasn't sure!, thanx
Old Sep 29, 2006 | 11:57 AM
bronco521's Avatar
bronco521
there should be a number cast in to the casing,like 44f,60f or 70.just have to do some scrubbing.usually covered in gunk.
Old Sep 29, 2006 | 08:17 PM
LedheadELH's Avatar
LedheadELH
yea, I know all about the number cast into the webbing, well in the 70's case, I'm pretty sure the 44 is on the bottom of the pumpkin.....I think the 60 is just like the 70, on the webbing.
sdunham
Nov 16, 2016 01:44 PM
Dean06919
Jan 25, 2016 06:50 AM
BlueOvalBud
May 17, 2012 02:15 PM
Four Paws
Feb 9, 2010 09:53 AM
billathardcore4x4
Jan 23, 2000 10:18 PM
