35-40 mph vibration
Old Sep 22, 2006 | 07:23 AM
oldstylefseries's Avatar
oldstylefseries
35-40 mph vibration
Fellas,
Need some help here. 95 f150, supercab-short box, 351, E40d, 3.55 limited slip rear.
Got a steady vibration from 35-40 miles per hour. Not above, not below. Doesn't matter whether in neutral, on an accel, or a decel. The U joints are fine, as is the midship bearing. The ONLY thing that has changed is that I took out the steering column a couple of weeks ago to fix the sloppy shifter. That is in right, the steering shaft is back in the original position. The ONE thing that bothers me is that this showed up after I fixed the column. There should be no connection. The vibration is not in JUST the steering column. The vibration is in the whole truck, and it's pretty bad.
Any ideas?
Thanks.
Old Sep 22, 2006 | 08:55 AM
Conanski's Avatar
Conanski
Could be a bad tire with broken cords or a warped/bent rim. Jack up each corner and spin the wheel looking for warpage and or tire problems. If you have spares swap out a pair and test drive. If everyting checks out, you may have an unbalanced driveshaft. A competent dealer can find and rebalance this.
Old Sep 24, 2006 | 10:56 PM
puck1263's Avatar
puck1263
a noise/wobble/vibration that is present at high speed but not low speeds has a very high percentage that it is a tire problem. Make sure they are balanced properly and are ok structurally (no belts slipped, etc.)
lostintexas
Jan 15, 2017 08:51 PM
Hansen13
Nov 27, 2015 09:00 AM
taylor13
1997 - 2003 F150
Jun 19, 2013 01:48 AM
berry1234
Apr 18, 2011 05:02 PM
4.0 Beast
Nov 16, 2008 03:04 PM
