Changing lower ball joints on a Volare clip
Old 03-21-2005, 05:25 PM
jwcnj45
jwcnj45 is offline
jwcnj45 is starting off with a positive reputation.
While having the front end aligned on my 48 last Saturday my front end guy brought it to my attention that one of my lower ball joints was going bad. My question to any of you with the Volare setup is, can I change the lower ball joints with out removing the lower control arm or does it have to be removed and the joint pressed out?
Old 03-21-2005, 09:37 PM
CIAF's Avatar
CIAF
CIAF is offline
CIAF is starting off with a positive reputation.
I do not know why you would have to remove the lower to get the ball out. Just be sure to hold the weight of truck up from the lower arm. remove the upper and spindle/rotor so you have lots of room to work. I did it like that on a friends truck with no prob at all. I rebuilt my own off car since it is new construction and to powder the arms. USE CAUTION /Wear gloves.
PS: The socket for the upper is also a free rent at Autozone. ( Loosen while still on car)
Old 03-21-2005, 09:48 PM
fatfenders's Avatar
fatfenders
fatfenders is offline
fatfenders has a good reputation on FTE.fatfenders has a good reputation on FTE.fatfenders has a good reputation on FTE.
I believe it could be pulled on the car with a balljoint press. Available for a free rental from Autozone etc. Don't try to bang it out with a hammer. It won't happen. And the upper joints screw in if you ever do those.
scsprop
09-18-2014 09:22 PM
peter p
1997 - 2003 F150
09-02-2009 07:04 PM
jvaski
1997 - 2003 F150
03-24-2009 08:38 PM
raerjim
03-03-2009 10:26 PM
blitzkraig56
03-01-2004 02:48 PM
Quick Reply: Changing lower ball joints on a Volare clip
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
