Sponsored by: Real Truck
A different grill ?
Old Sep 20, 2006 | 02:39 PM
rhoadc's Avatar
rhoadc
A different grill ?
I tried to search but didnt find what I was looking for.
Has anybody added "mesh" behind the grill? Looking at my 04 the sides of the grill have a hexagon shaped mesh in the grill but the main grill is wide open. I was thinking that adding some of the blk plastic mesh behind the main grill would look clean and protect the fins as well. Has anybody tried this??? i would like to see a picture of the "after".
Hope that makes sense, if not I can post a pic.
Thanks
Old Sep 23, 2006 | 07:09 PM
250 STANG's Avatar
250 STANG
I have the same grill you have . What I did was order a Grill Insert Kit from Summit ,I have no hex behind my grill either only on the sides. If this makes sense to you , I installed the grill kit useing my on made brackets to hold the inserts in place . you cant use the ones in the kit ,they bolt to the hex that you dont have. It was simple , cut 8 strips of metal 3/4 wide about 4 in long and bent 90 degree on one end of metal strip , I then notched out the in side of grill to hold the brackets in place , get a strip of black truck cap tape and lay over your bracket , faceing out ,this will help hide the bracket and any rust,and also help holding the brackets in place ,then I used the supplied bolt and nuts , Took about an hour and 1/2 . Looks perfect !!!!!!!!!
Old Sep 24, 2006 | 10:14 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
I installed mesh behind my grill, I also removed the hex plastic on the sides and installed it there also (a bird already removed half of it on one side so I finished the job). What I used was the mess off our old C band dish and painted it white to match the truck. You can't install it in one piece because of the structure behind the grill. I attached it with small tie raps and small holes drilled in the grill.
Denny
superdutyon37s
6.7L Power Stroke Diesel
41
Apr 24, 2014 06:01 AM
BarnieTrk
Jan 1, 2014 08:14 PM
afinepoint
Appearance & Dress-Up
Mar 20, 2008 10:31 AM
ceetwarrior
1947 and Older Ford Trucks
Oct 13, 2004 09:37 PM
exzist51
Jul 22, 2003 04:22 PM
