tranny swap
Old Sep 21, 2006 | 12:37 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
The stick fun I have is the 95 Rover Disco (wife drives it soccer mom) it has a ZF 5-speed synchro reverse. This with a cam, chipped 4.6 vs stock 3.9, ported heads and exhaust system plus heavy sway bars and springs (street no dirt vehicle) a surprise vehicle against many lesser brands. With 6 vehicles the truck is the only slush box, others stick.
As he slams left foot on the brake reflexing for the clutch, happens more than I want to addmit.
.....=o&o>.....
Old Feb 17, 2007 | 11:26 PM
fredford's Avatar
fredford
I'm new to this forum and have been going through posts trying to research what I'll have to do to swap the drive line from a 1971 LTD with a 429 and c6 into my 1970 F100 ong bed with a 240 six and 3 on the tree. I understand that I should relocate the drain plug on the engine to the back of the pan, and that I may have to get a RH side truck exhaust manifold since the car manifold doesn't have enough clearance when put in a truck. What other modifications do I have to do to the transmission and drive shaft to make this switch. I wanted to put a floor mounted transmission shifter in it and will have some fabrication to do to make that work. Any information and advice you might have would be appreciated
devall97obs7.3
16
Oct 15, 2014 09:41 PM
351viC
May 2, 2006 07:11 AM
fordfan2018
Feb 20, 2004 11:52 AM
frenchf250
Dec 24, 2003 12:46 AM
skeeze
Jun 1, 2002 11:29 PM
