Sponsored by: Auxito
99 F150 power door lock problem
Old Sep 20, 2006 | 12:25 PM
FordLou's Avatar
FordLou
Can anyone help troubleshoot a power door lock problem? The problem is happening on both doors using either power door lock switch. When you try to lock or unlock the doors using either switch, you can hear it try to move, but very little movement occurs. Repeated attempts to actuate the locks results in weaker mechanism movement? Anyone know if this is the actuator(s) themselves or something else? I find it odd that both would be malfunctioning at the same time to the same degree. Thanks for any help. Lou.
Old Sep 20, 2006 | 02:25 PM
oscar_007's Avatar
oscar_007
door lock actuators
My 2000 F-150 had the same problem with the door locks, but they didn't both go out at exactly the same time. The drivers side went out first and then about 2 months later, the passenger side went out. I ended up buying two new door lock actuators and I put them in myself. It took me about 4 hrs.
I bought the actuators from a Ford Dealership and they costed about $75 a piece!! I recommend maybe try buying them off ebay or somewhere else where they may be cheaper.
Old Sep 20, 2006 | 04:40 PM
FordLou's Avatar
FordLou
Did the replacement have any tricky parts in the process or is it pretty straight-forward? Thanks for responding. Lou
Old Sep 20, 2006 | 04:52 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
or you could buy OEM factory from me for $44.30 ea
6L3Z25218A42AA (RH)
6L3Z25218A43AA (LH)
In stock ready to ship.
Ed
Old Sep 20, 2006 | 05:24 PM
captaineasy's Avatar
captaineasy
I used aftermarket actuators on my 00 f150 I got from a local audio and alarm shop for $15. U have to relocate the actuators but work as well as the OEM. took about an hour to decide where to put it. 15 min. to install.
CUINAK
Sep 27, 2019 10:48 AM
dcchadwick
Mar 6, 2016 10:10 PM
smh111
1978 - 1996 Big Bronco
Apr 1, 2015 04:20 PM
ryankerr
Electrical Systems/Wiring
Mar 5, 2014 10:06 AM
bluef72
Oct 17, 2013 11:26 PM
