DP 60 vs 80 tow
Old Sep 19, 2006 | 09:25 PM
kbeefy's Avatar
kbeefy
DP 60 vs 80 tow
OK, I kinda asked this before but was distracted by a CPS problem at the same time.
Anyways, I was wondering if anyone else has a DP tuner with both 60hp and 80hp tow settings?
I have these settings and cannot tell the difference between them. I also have the 80econo setting and can tell a definate difference between it and the 80 tow setting.
I talked to DP this morning and they said that I wouldn't be able to tell the difference between 60 and 80, in which case, I've wasted $45 because I have 2 settings that behave exactly the same.
Hope someone can shed some light, maybe DP and I have miscomunicated...
Old Sep 19, 2006 | 09:40 PM
white Buffalo's Avatar
white Buffalo
I have a 4 position chip from Total Diesel Performance (Tony Wildman). I currently have two tow programs also. I use the higher HP Tow program on the flats and the lower HP tow in the hills & higher grades. You might not fell the difference in the pedal but you should show lower EGT's on the 60 Tow. Have you towed with these programs yet?
Old Sep 19, 2006 | 10:18 PM
kbeefy's Avatar
kbeefy
I don't have my EGT installed yet so when I towed I kept it in 60, except for a few brief experiments. No difference in response or how it feels, hopefully I'll get the egt installed soon for further info.
Old Sep 19, 2006 | 10:42 PM
KrenzyRyan's Avatar
KrenzyRyan
Better get that EGT asap.
Old Sep 19, 2006 | 10:58 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Rich is right, I have the F5 DP-Tuner with 40tow,60,tow,80tow,80econo and 120fun. I got three tow settings to better control EGTs. 80econo is best suited for empty interstate driving. The 80tow is good for 6K and below towing, since my TT is 9K I figured that I would start off in 80tow and when the EGTs rise passed my comfort levels I would drop it to 60tow and then 40tow if need be. By the way, Diane says that the best setting for fuel economy in the city is the 60tow. So if you think about it, you did'nt waste your money.
Old Sep 20, 2006 | 12:22 AM
kbeefy's Avatar
kbeefy
OK, so you have about the same tunes as me... can you tell a difference between 60tow and 80tow?
Old Sep 20, 2006 | 06:16 AM
white Buffalo
Better get them guages quick before something goes Kaboom
Old Sep 20, 2006 | 06:44 AM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
What you should only feel the difference in between the 60 tow and 80 tow is a slight increase in line pressure in the 80 tow. SOTP you may not feel it. HP wise no you most likely will not see a difference. Now between 40 tow and 80 econo. Yes you should see a difference in HP because of the difference in HP range.
Diane
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Sep 30, 2006 | 03:52 PM
KrenzyRyan's Avatar
KrenzyRyan
Diane
Hmm, ok. I have the chip and I was wondering which tune is recommended for driving around town... I know to use the 80 econo for highway.
Old Sep 30, 2006 | 09:30 PM
kbeefy's Avatar
kbeefy
I like the 60 tow for around town... never use 80 tow 'cause it's the same. Crank it up to 120 when I wanna show off.
Old Oct 1, 2006 | 02:53 AM
KrenzyRyan's Avatar
KrenzyRyan
Yeah same here kbeefy. I usually run 60 round town...What tune gives you the best mpg for around town?
Old Oct 1, 2006 | 02:38 PM
kbeefy's Avatar
kbeefy
stock because I can't keep my foot out of it in anything else!
Old Oct 1, 2006 | 09:56 PM
KrenzyRyan's Avatar
KrenzyRyan
But it shifts and rides so well in 60 around town!
akmikek
27
Apr 17, 2015 02:54 PM
good9682
Oct 15, 2013 12:16 AM
puffen:D
19
Oct 9, 2007 12:39 AM
hdman6
15
Feb 15, 2007 02:54 PM
00xlt
Mar 26, 2006 09:03 PM
