under the hood
Old Apr 14, 2001 | 03:05 PM
twr's Avatar
twr
under the hood
sorry about the other post I'm not sure what happened.
I'm ready to change my front end to newer version with disk brakes. Can I use the master cylinder off a newer truck as well?
I also was wondering about power steering and changing the whole system including the steering columm can I do this and how hard is it?
I have a choice of three different trucks to use a 75,77,79
for a donor truck is there a better choice ?
Old Apr 14, 2001 | 04:04 PM
jowilker's Avatar
jowilker
under the hood
Trev, Grab the master cyl. Most here would suggest that you use it for a core exchange on a reman. or new if you prefer. If you are just grabbing the brakes, it won't matter because all are the same from the factory. Find the donor with the tightest feeling front end and grab the complete I-beams and swap them with all the lines and mounting brackets.
You may want to add power steering too while you are converting to easier driving.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old Apr 15, 2001 | 06:12 PM
64 f100's Avatar
64 f100
under the hood
Old Apr 16, 2001 | 05:34 AM
William's Avatar
William
under the hood
twr, I also advocate installing a power steering system when you do the brakes. The power steering gear is a good place to mount the proportioning valve and the brake/power steering lines. I prefer the original I beams because they have an adjustable steering stop and I use the original (Cast) radius arms. I think this old stuff just looks better. I install new king pins and bushings on the bench (easier since I'm not very flexible anymore). I core exchange the steering gear, master cylinder and calipers. Resurface the rotors, install new pads, tie rods, drag link, PS hoses, brake hoses, wheel bearings and seals and I make new steel lines to fit. If you can afford it replace the TS switch and horn brush. While the truck is on the road use a little kerosene and high pressure wash to clean the frame, fire wall and front part of the engine. Makes working on it a little more pleasant. Don't rush this job! I remove everything (column, I beams, radiator, master cylinder)and start reassembly by installing the steering gear box. It is a heavy SOB!
William in Atlanta
Old Apr 19, 2001 | 05:19 AM
twr's Avatar
twr
under the hood
thanks for the help guys when I get farther along I,m sure I will need some more help.
Thanks again Trevor
papazig4726
Jan 23, 2015 05:47 AM
BIG-DADDY-F350
23
Feb 11, 2012 05:31 PM
sphinx
Aug 4, 2009 02:23 PM
GHog
Offroad & 4x4
23
Jul 20, 2006 11:38 PM
