Modular V10 (6.8l)
Recall...
Old Sep 19, 2006 | 12:42 AM
Kamots's Avatar
Kamots
Exclamation Recall...
He guys, did you all get a recall on the speed sensor thingamajiggy. It was a 2 minute fix today for me. And in the little town i was in they already had 5 trucks burn to the ground. I was shocked. And VERY happy its done an over. Id like to tell you what an were the part went, it looked like a fusible link from the distance, but i was flirting with a short skirted 30 sumthing with ummm really brite headlights...and red hair. Looked like a cheerleader, i sure know i was cheering..hehe. So have you guys heard of this?
Travis
Old Sep 19, 2006 | 11:22 AM
superduty lee's Avatar
superduty lee
Yes, I have heard of those short skirted 30 year olds, and they can be big trouble.
Old Sep 19, 2006 | 12:11 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
It's not a speed sensor.
It's the cutoff switch for the cruise control when you hit the brakes. It's a pressure switch, screwed right into the master cylinder. It's fed at ALL TIMES with 12 volts at 20 amps. More than the switch can carry. When the switch leaks internally, it shorts out, can't possibly suck 20 amps, doesn't blow the fuse, just burns the truck to the ground.
This has been known about for years, but it took Ford a long time to finally recall the SD's.
The fusible link is (I think) setup for 5 amps.
I still have to bring mine in to get it done, and then right afterwards, I'm putting a relay inline so it's not powered hot at all times.
Old Sep 19, 2006 | 06:10 PM
Kamots's Avatar
Kamots
Ahah, very good idear Krewat. Thankx for mentioning that, i do believe i will add that little mod to my beast.
Hehehe im still thinking bout that short-skirt...hehe.
Old Sep 19, 2006 | 06:32 PM
Zip's Avatar
Zip
Just got mine in the mail last week. Will have to make an appointment to get it done. Only thing is the nearest dealer is a little over an hour away.
Old Sep 19, 2006 | 06:42 PM
1979Mustang's Avatar
1979Mustang
Got mine done as soon as I got the recall in the mail about a month ago.
Old Sep 19, 2006 | 08:56 PM
Racerguy's Avatar
Racerguy
Two of the Super Dutys I did the recall on today had brake fluid in the connector on the switch.
If you can't get in soon to have the recall done it may be a good idea to unplug the switch.
Old Sep 19, 2006 | 09:07 PM
krewat's Avatar
krewat
You are VERY correct!
Mine has been unplugged for two YEARS.
Old Sep 19, 2006 | 10:03 PM
BigRyanKP's Avatar
BigRyanKP
why not just replace the switch if its defective, mine has been unplugged ever since i first heard of this.
Old Sep 19, 2006 | 10:18 PM
Ace!'s Avatar
Ace!
Sorry if I missed it, but what year trucks?
Old Sep 20, 2006 | 10:51 AM
chris60's Avatar
chris60
at least back to 1996.. up unto ? My sisters F150 has the same recall. I unpluged her switch for her as suggested. and both my 00 trucks have had the recall.
Old Sep 20, 2006 | 02:11 PM
rebelford11's Avatar
rebelford11
I still have to get mine done, where is it located so i may unplug it until I can have it fixed.
Old Sep 20, 2006 | 02:39 PM
rob17's Avatar
rob17
Is this a recent recall? I haven't seen any notice.
Rob
Old Sep 20, 2006 | 07:22 PM
krewat's Avatar
krewat
The switch is on the bottom of the master cylinder, towards the front of the vehicle.
On my '01, it is slightly angled towards the driver's side.
Old Sep 20, 2006 | 08:15 PM
cc322's Avatar
cc322
Can someone please post a copy of this recall and the years, I have not recieved a notice on my 2003?????
