tranny fluid change
Thanks
Dennis
06-14-4 MERCON ATF IS BEING REPLACED BY MERCON V ATF AS A SERVICE FLUID.
Publication Date: June 29, 2006
FORD:
(I deleted all the other vehicle to shortnet this up a bit)
1981-2004 E-Series, F-Super Duty
This article supersedes TSB 01-15-7 to update the vehicle application chart.
ISSUE:
MERCON® Automatic Transmission Fluid is being replaced by MERCON® V as a service fluid.
ACTION:
Beginning immediately all automatic transmission / transaxle applications requiring MERCON® can now be
serviced using MERCON® V or MERCON® Automatic Transmission Fluid or dual usage fluids labeled
MERCON® / MERCON® V. After July 1, 2007, MERCON® Automatic Transmission Fluid will no longer be
manufactured, therefore, availability of this fluid will only continue for however long it takes to deplete what
remains in inventory.
SERVICE PROCEDURE
Service automatic transmissions requiring MERCON® with MERCON® V or MERCON® Automatic
Transmission Fluid or dual usage fluids labeled MERCON® / MERCON® V
For proper fluid application on current and past model vehicles equipped with automatic transmissions /
transaxles refer to the fluid usage chart. (Figure 1)
CAUTION: AUTOMATIC TRANSMISSIONS / TRANSAXLES THAT REQUIRE MERCON® V SHOULD
STILL ONLY USE MERCON® V OR DUAL USAGE FLUID LABELED MERCON® / MERCON® V.
CAUTION: MERCON® SP, MOTORCRAFT PREMIUM AUTOMATIC TRANSMISSION FLUID AND
MOTORCRAFT M5 ATFS ARE UNIQUE FLUIDS AND MUST BE USED IN APPLICATIONS
RECOMMENDING THAT PARTICULAR FLUID. USE OF ANY OTHER FLUID MAY CAUSE
REDUCED FUNCTIONALITY OR TRANSMISSION DAMAGE.
CAUTION: THE FUNCTIONAL CHARACTERISTICS OF FLUIDS FOR CVT TRANSMISSIONS ARE
VERY DIFFERENT THAN THOSE OF OTHER AUTOMATIC TRANSMISSION FLUIDS (ATFS). USE OF
A FLUID OTHER THAN MOTORCRAFT CONTINUOUSLY VARIABLE CHAIN TYPE TRANSMISSION
FLUID OR ONE LABELED AS MEETING MERCON® C WILL CAUSE FUNCTIONALITY CONCERNS
AND INTERNAL TRANSMISSION DAMAGE.
CAUTION: DO NOT USE AUTOMATIC TRANSMISSION FLUID SUPPLEMENTS, ADDITIVES,
TREATMENTS OR CLEANING AGENTS.
PART NUMBER PART NAME
XT-2-QDX MERCON® (Quart)
XT-2-DDX MERCON® (55 Gal. Drum)
XT-5-QM MERCON® V (Quart)
XT-5-DM MERCON® V (55 Gal. Drum)
WARRANTY STATUS:
Information Only
Figure 1 - Article 06-14-4
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians
with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of
conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service.
The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described
affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin
applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or
Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical
Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede
this information with updates. The most recent information is available through Ford Motor Company's on-line
technical resources.
. thats news to me.
thought we weren't supposed to mention the "other" forum, hehe...
