I am building a rat rod out of my 51 f1 and need to start thinking of wiring, painless wont do and ron frances is over priced. if you got any ideas please let me know.
thanks for the help guys, when i called painless and gave them my application the sales rep i talked to said that the universal kit might not meet up with what i am trying to do so that was the only problem besides the price. Also i have to go from 6volt to 12 volt. I work in a parts store and one of the guys there said something about a company called kwik wire, anyone know anything about that?
kelt, I have a 54 I put a 302 and a aod tranny in. I've actually redone the whole truck. After going to so cal they suggested I use a haywire kit for about half the price of painless and it seems like it will work pretty well . I've mounted the fuse block and run the wire bundles to ft lights ,rr lights, engine harness and dash . will start hooking them tomorrow . I will let you know how it came out. bill
I've done wiring on several vehicles in the past. The aftermarket wiring systems are easy to install and require less electrical savvy. If you have the time and patience you can use the wiring harness of most any modern vehicle. I used the one from my 87 Chrysler donor vehicle mainly because I used the Chrysler column. I could have spent the bucks on an aftermarket kit but was trying to build on a budget. I saved about 150 bucks by using the donor car harness but it took me a week to sort it all out. It's going to work out great but it's a lot of trouble. My recommendation is go with a reputable aftermarket harness. Ron Francis is pricey but you have to pay if you want the best. Painless is also good. I have used both.
I used the EZ Wiring 21 circuit harness for my 49. It has more circuits than I will probably ever use, but I have them just in case. The kits is easy, color coded, labeled, etc. I bought my harness for $150 on Ebay.
I built my own wire harness. I didn't like the quality of the reproduction harness I bought for my '49 F-2. After only 7 years the insulation is fraying, exposing the wire. I am using modern, rubber coated wire that is oil resistant and more flexible. I also wire industrial control systems for a living so I feel I should do it myself. I want it to look somewhat like OEM so I have made the connections looks as close to OEM as possible.
Here are a couple pictures of the wire connectors I made:
I can understand with the repro harnesses which use cloth insulation like OEM, but the universal harnesses use modern plastic insulated wire like current vehicles use so I don't expect insulation breakdown to be a concern.
