Ignition Upgrade
Old Mar 22, 2019 | 12:07 PM
78Fords's Avatar
78Fords
Ignition Upgrade
i am looking to replace my stock dist on my 78 300, i dont know alot about ignition but i have done some research on 300 ignition upgrades and i dont know if i want DUI HEI or just stock. if anyone can explain the differences (in English) i would greatly appreciate it. i found this... https://www.ebay.com/itm/FORD-300-24...kAAOSw1DtXDu36 but i dont know about the quality of the brand and if this is something i can do. any advise and experience is appreciated.
Old Mar 22, 2019 | 12:45 PM
ford390gashog's Avatar
ford390gashog
Same brand I used, works well and was good quality. Good news is the parts for maintenance are easy to get, the cap is from a 4.3 V6 GM and the rotor and module are standard GM parts.
Old Mar 22, 2019 | 02:22 PM
78Fords's Avatar
78Fords
great! how hard is an instal with a relay to get the higher voltage, instead of just going through the normal ignition switch without another relay. i know some guys do this because the normal ignition has a resistor.
Old Mar 22, 2019 | 03:44 PM
ford390gashog
It's a easy swap, the + wire of the old coil to the new HEI distributor. Remove the duraspark wiring and remove the pink ballast resistance wire from the cab. Had my whole swap done and timed in under a hour driving.
Old Mar 22, 2019 | 07:02 PM
FuzzFace2's Avatar
FuzzFace2
I got to ask what makes you think putting in a GM HEI dist. in place of the Ford's DSII is a up grade?
I know of someone that used a stock (advance locked) DSII in a drag car and ran 11 second 1/4 mile times and 10 second on spray.
So why do you think the HEI is a upgrade over a large cap DSII set up?
Now if you were running points I still would not go with the GM HEI but a point replacement kit like Pertronix.
Dave ----
Old Mar 26, 2019 | 10:19 AM
78Fords's Avatar
78Fords
i am just looking for an easy distributor swap and when i say upgrade its not much of an upgrade it will just have less wiring and i wont have a coil on the engine, wont have to worry about it over heating because mine is currently mounted horizontally and i have heard that they need to be vertical. i think the built in coil looks better, and i need a new dist anyways so i thought i might as well get what works, looks, and performs the best. i know its not a magic instant horsepower part, nothing is, but i have heard of better idling and better timing curve adjustment in the hei distributers.
Old Mar 28, 2019 | 02:38 PM
Kramercd's Avatar
Kramercd
I can't verify the information, but it sounds reasonable. This post explains different coil types and orientations. https://www.ford-trucks.com/forums/1...l#post18426775
Old Mar 28, 2019 | 05:10 PM
Harte3's Avatar
Harte3
gofastforless.com
Info on ignition upgrades.
Old Apr 7, 2019 | 07:27 AM
78Fords's Avatar
78Fords
okay so i am looking for a pertronix unit for the 78 4.9 and cant find one, has anyone used a pertronix unit in this year, it doesnt have points to begin with so i assumed it wouldnt have a conversion unit as there is nothing to convert
Old Apr 7, 2019 | 12:01 PM
pmuller's Avatar
pmuller
Your Duraspark ignition is an electronic system without points so why go to a Pertronix?
Initially you wanted to use an HEI style system to minimize the amount of wires in the engine compartment so what changed you mind?
Old Apr 7, 2019 | 07:25 PM
fordman75's Avatar
fordman75
I feel the best upgrade is just add one of the MSD 6 igniton boxes and coils to the stock distributor. I think the GM hei set ups look horrible and they have issues of their own. If you do get one make sure to get some spare parts to carry with you.
Old Apr 8, 2019 | 02:16 PM
78Fords's Avatar
78Fords
yeah i didnt want the GM dist. i found a different kit on CRT performance that looks ok... https://crtperformance.com/shop?olsP...x-shaft&page=1
but i dont know if it is still a gm cap and rotor, CRT wont answer any of my tech questions
Old Apr 8, 2019 | 04:30 PM
pmuller's Avatar
pmuller
The Ford Duraspark caps are a lot larger in diameter and screw down and the later caps are screw down also.
The CRT cap doesn't look like a Ford cap
Adding to what Fordman75 said. Our experience has been that the best system to add both performance and fuel mileage on a Ford 300 six is the MSD 6A or 6AL.
Just add the MSD box to the Duraspark system that you already have.
https://www.dropbox.com/s/8pjhh805lx...e-001.jpg?dl=0
Old Apr 8, 2019 | 10:20 PM
Harte3's Avatar
Harte3
I did that with a Mallory 6A...added it to my stock DS2 system.
Old Apr 12, 2019 | 08:54 AM
78Fords's Avatar
78Fords
Anyone ever bought a refurbished MSD 6AL off ebay Sold by MSD?
