i need springs on the front of my 82 f150 4wd that need to be at least 2 inchs taller. summit list them with 400 lbs/in force that fit a 80 - 96 ford. but they also have 475 lbs/in springs but they fit a 90 - 96. I'd perfer heavier springs so i can install a plow. my question is will they fit the older models, did ford use the same springs from 80 thru 96?
