1966 - 1977 Early Broncos
Transfer Case OIl
Old Sep 17, 2006 | 12:08 PM
chefddh's Avatar
chefddh
Transfer Case OIl
I need to refil my dana 20 trans case and my rear differential how much fluid do I need and can I use 80/90 gear oil for both?
Old Sep 18, 2006 | 02:56 AM
fordtrucksforever's Avatar
fordtrucksforever
Yes the 80/90 works for both. Depending if all fluid is completely drained. At about $8 a gallon, two should get everything with some to spare.
Old Sep 23, 2006 | 07:54 PM
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
On my glove box lid it says to use 50W in the transfer case (maybe easer to shift in the winter). I have not asked at the parts store but I guess it would be available. But as fordtrucksforever said I think you will be just fine with 80/90.
Tim in Chelan
Old Sep 24, 2006 | 07:42 PM
fishmanndotcom's Avatar
fishmanndotcom
in gear driven cases (Dana 20, NP205, etc) heavy weight (80/90) is recommended to help coat the bearings and keep them coated. in real cold areas such as northern states that see negative temps a thinner weight is recommended so that as the temps get colder the oil can stil get in the bearings and keep them coated instead of the oil gettin all syrupy!
in chain driven cases (np208, np203, etc) tranny fluid is recommended b/c the chain is harder to get oil coated on the inside so they use a much thinner oil. otherwise the chain would burn up
-cutts-
Old Sep 25, 2006 | 02:05 AM
fordtrucksforever
One real problem with using 50W oil. Its readily available. I use it in a high milage truck just to keep oil pressure out of the red. Good truck, but very loose inside. In the Dana 20 transfercase, it will leak all over the place. The bearing plates and shafts are not gasketed, glued, or oringed. With the milage on these, you have clearance. And then there is a big mess everytime you stop. Next time I go thru one, its getting grooves cut in the shafts for orings and figure a simple way to seal the shimmed bearing plates. I really hate to silicone all of these pieces.
Old Sep 25, 2006 | 11:23 AM
RCrawler's Avatar
RCrawler
If the surfaces are clean, silicone works great on the endplay adjustment shims and will last a long time.
50 Wt Transmission oil (not the same as engine oil) is the factory recommendation for transmissions and transfer cases. I've used both and the only time I may have noticed a difference is in extreme cold conditions -30 deg F.
Jason
tlbranth
20
Apr 26, 2014 08:51 PM
wolffee
Dec 11, 2011 07:10 PM
Robby Nash
Oct 19, 2011 09:43 AM
pcguy760
Nov 20, 2008 10:48 AM
fordguy76
Oct 18, 2002 03:01 PM
