E4OD Conversion (need help) 4x2 to 4x4?
Old Sep 16, 2006 | 10:37 PM
camccardell's Avatar
camccardell
Question E4OD Conversion (need help) 4x2 to 4x4?
hello,
well my 95 f-150 4x4 has finally hit the 220k mark. Rather impressive I'd say since I haven't had to change anything major yet, except the suspension and steering.
The E4OD is tired. Sometimes when I press the gas pedal nothing happens when I am moving. It is really strange, and then the tranny kiks in and everything is good again.
Well I think I need a new one, or a rebuild. Malco and others want over 2k for it and I think that it is a bit too much.
Can I take a 2wd E4OD and convert it to 4x4 and hook it up to my transfer case?
Are there any other alternativies?
Thanks
Chris
Old Sep 17, 2006 | 12:21 AM
Blurry94's Avatar
Blurry94
Try doing a complete fluid/filter flush before replacing it. Drain the pan, cooler (if equiped) and the converter. Converters equiped with a drain plug can be accessed by removing the rubber gromet/plug at the bottom of the bell housing; you may have to rotate the motor around to gain access to the conveter drain plug. All of this can be done without removing the trans.
Old Sep 17, 2006 | 12:24 PM
andym's Avatar
andym
Matt's suggestion is a good one. But if it needs a rebuild, you're going to shell out $2500 to do it, regardless of who does the work.
And for god's sake, stay away from aamco. Best case, they are incompetent. Worst case, they will rip you off for shoddy work. They are known for this. I have heard so many horror stories from that chain.
Old Sep 18, 2006 | 09:14 AM
Casey's Avatar
Casey
Yes, you can.
Take EVERYTHING out of the 2wd trans. Install the output shaft from a 4x4 trans. Reinstall every other part of the trans. Leave off the extension housing.
Old Sep 18, 2006 | 09:23 AM
Tsaven Nava's Avatar
Tsaven Nava
Good lord, $2500?! The place down the street from me rebuilt my E40D for $975
plowboy1986
Nov 24, 2016 07:34 PM
Blind Driver
Feb 29, 2016 11:43 AM
Chris 56 f6
1947 and Older Ford Trucks
88
Jul 20, 2015 05:37 AM
ml8on
1978 - 1996 Big Bronco
15
Apr 23, 2014 11:58 AM
