Noisy Turbo?
Old Sep 16, 2006 | 04:20 PM
maybeanightmare's Avatar
maybeanightmare
Noisy Turbo?
Just bought a '06 super duty and noticed that when you turn off engine, you can hear the turbo wind down with a loud rattling noise. Is this normal, our '94 7.3 with banks turbo and exhaust didn't do this. Also where do I find the build date and does ford care if you put on a turbo-back exhaust system omitting the cat.
Thanks for your help!
Old Sep 16, 2006 | 08:05 PM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE maybeanightmare
Check out the Tech folder. https://www.ford-trucks.com/forums/3...ch-folder.html
Our search function will provide you much information and reading.
Also https://www.ford-trucks.com/guidelines.html
To answer some of your question.
Was the truck purchased new? Build date of the engine is located on the FICM (Drivers Side Valve Cover) and for the exhaust, depends on how mod friendly your dealer is plus the area you live in. A Cat-Back exhaust system will lower your exhaust temperature.
Old Sep 17, 2006 | 12:23 PM
BowTieHatr's Avatar
BowTieHatr
ya they do make a little noise on shutdown. let it idle for a secoond or two before shutdown will let the turbo spool down.
CowboyFromHell
17
May 3, 2008 11:38 PM
hselin
Jul 29, 2007 12:55 AM
96powerstroke
26
Mar 17, 2007 02:36 PM
PSD6litre40
Sep 20, 2004 07:35 PM
The Grinch
Jun 15, 2004 12:59 PM
