aftermarket turbo
basically the only kit we can get for our older trucks is from www.gohypermax. c o m However you will need larger injectors and a chip to make full use of it. Your stock turbo works decent until you reach the 400hp mark. I would suggest you try a chip from Tony Wildman and see if that takes care of your hp needs. With a chip you'll also need at least gauges, exhaust and intake- Tony can also set you up with those. If a chip alone is not enough next step is injectors and intercooler. Give Tony a shout at 817-932-5078.
lukes turbo....ill let him release that but its BIG with that under the hood i wonder how it doesnt suck the hood in.
another turbo upgrade and the route i took was change uppipes and pedistal to the superduty one and use a van turbo, but then at that point you have more choices of turbos like the turbonetics which i prefer or the garrett
but again its gonna take more fuel to spin larger turbos and intercoolers are a very highly reccomended.
something that you can do to get the stocker to spin up faster is a smaller exhaust housing that works great without having to go with larger injectors
Originally Posted by tjbeggs
Luke your secret is safe here!! What are you running for a turbo??
Also what turbo is the H2E based from? Is it a one off or is it a modified _______??????
The h2e (62mm inducer i think) is an off the shelf turbo and i believe was very common on L10 cummins engines. It can be modified with a bigger compressor wheel. I picked up about 50 hp just just by switching from a stock h2 to a modded h2 (66mm inducer)
on
Thanks Luke for letting your info out! and for the info on the H2E. I thought that I heard the H2E was a L10 turbo. I was eyeballing one a few months ago when I did a head gasket on an L10 and the turbo needed rebuilt but the customer already dropped a couple grand on the head gasket after I found a cracked head (common for L10's)
I will probably never get that far in my mods but it nice to have that info tucked away for furture reference!
