I just installed my 4" MBRP Turbo back exhaust this morning and an really happy with it. I plan on getting a delete pipe.
On to the question: I ran it around for a while then checked the bolts and noticed some black oil type liquid coming out of the joints. Is this normal is this a problem? Should I be concerned?
Did you use a lubricant on the pipes when you assembled the exhaust?
Torque values are worthless on marmon clamps. Tighten it only enough to take any "wiggle" out of the t-bolt and leak check it. Only snug it up further if it's leaking.
I did not use any lubricant when I assembled the new. Only thing I used was WD-40 to get the old DP loose from the Turbo, doubt that is it. There is only a little bit of this coming out. Very little. Just enough to notice.
Something else that is a bid wierd is the sound of the truck when I turn it off. It almost sounds like the motor knocks as it comes to a stop. Has anyone else noticed any sounds such as this after the installation of new exhaust. Maybe it is just more audiable because of the bigger exhaust???
Well I loosened all the hardware and tried pulling, twisting, torking, hammering, kicking, and swearing, then finally I think I got the DP to twist a tad. Well I tightened everthing back up and no more knocking. We'll have to see if it holds!
i have a 4" muffler delete pipe laying around the shop if you want it, you can have it. i had a muffler delete and it does me no good now with stacks. it is a few inches longer than the muffler as my muffler flange was crimped on to the pipe in front of it, so i had to cut it at the flange. i used Accu-seal clamps to make a secure butt-connection and it worked fine. let me know if you want it.
A couple of months ago when I went to the 4" turbo back system (no muffler) I dripped black oil for a few hundred miles. Now, 6,000 miles later have no drips at all. Where it came from in the first few hundred miles is still a mystery to me. I flat out love mine and wonder why anyone would bother with a muffler at all.
