Sponsored by: Auxito
How do I turn torque converter?
Old Sep 16, 2006 | 12:07 AM
tj90's Avatar
tj90
I have a 97 4R70W tranny (4.2L 4X2) and trying to drain torque converter. From searches n the site, I know that the drain plug can be accessed through the 2" hole at the bottom of the bell housing.
Sorry for asking a stupid question, but how do I turn the torque converter to access the drain plug??? I know I supposed to turn the flywheel but how? Is it a flathead screwdriver on the flywheel teeth? If so, what direction? seems like it take alot of force. There is a a cover forward the bell housing - should this come off to ease the flywheel turning?
I read the DIY on flushing the tranny, but Im thinking of just draining the pan, replace filter and draining torque converter and forgetting the cooling lines. I figure whats left in the cooling lines will just mix with new Mercon V. Is this crazy?
Sorry for asking a basic question, but Im tired of scratching my head and ready to get this job done!
Old Sep 16, 2006 | 05:39 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 16, 2006 | 05:54 AM
Joe Finn's Avatar
Joe Finn
When I drained mine, I removed the torque converter inspection cover. Then I started the engine and shut it off a few times until the drain plug was at the bottom. Only took a few tries.
You might want to do a search on trans fluid. As I seem to recall, you do not want to put Mercon V in a '97. FYI, there will be a plastic "thingee" in the pan. Just throw it away, it's a dip stick plug left there from assembly.
Old Sep 16, 2006 | 06:12 AM
stuart1's Avatar
stuart1
Use a deep socket and ratchet in the front pulley.
When you locate the plug remove the socket and ratchet.
Don't ask.
Old Sep 16, 2006 | 08:48 AM
steve(ill)'s Avatar
steve(ill)
i did the big screw driver trick on the teeth. turn either way, it only takes a couple minutes to find the plug. reinstall the plug with a couple drops of loctite. this method works real good, the small amount in the line done matter much.
Old Sep 16, 2006 | 08:50 AM
tj90's Avatar
tj90
Thanks for the information guys. I will try it again today. Also, thanks for the heads-up on mercon V as well. I will search this further. The Mercon V bottle says its good for all Mercon III applications, but if others have had problems.....The Mercon III has been working well for the last 125k miles.
I have changed the filter and dropped the pan probably 3-4 times already, just never drained the torque converter, so i have a blend of new and old in my truck now I guess. On the most recent drain, the fluid looked dark red and did not smell bad. I rarely tow or sit in traffic so the tranny has an easy life.
Old Sep 16, 2006 | 11:56 AM
skilife17's Avatar
skilife17
I had a similar question about Mercon V. The later 4R70W trannies take Mercon V and the older ones like 97 models take Mercon. take a look at this thread, it might help you out.
https://www.ford-trucks.com/forums/4...ml#post3558128
