Sponsored by: Auxito
which tranny
Old Mar 29, 2006 | 08:18 PM
acf83's Avatar
acf83
which tranny
on a 2003 ford f-150 how can you tell what tranny you have? i was going to change the fluid(49000) and don't know what fluid to get(mercon or mercon v), the transfercase in the owners manuel states to use mercon and if you have a 4x4(4r100), then the dipstick states use only mercon v(which would be the 4r70w). does the transfer case and the tranny use different fluids? seemed kind of odd to me. so i was hoping someone could shine a little lite on the subject. thanks andy
Old Mar 30, 2006 | 01:07 AM
acf83's Avatar
acf83
nevermind i figured it out, i see this this another worthless forum about which bolt ons are best. and what cat back sounds the best.
Old Mar 30, 2006 | 01:38 AM
tkondro's Avatar
tkondro
Good to see you can use the owners manual. And this isn't just a forum about which bolt on is best. There are some really knowledgable guys here that can answer just about any question.
Old Mar 30, 2006 | 08:40 AM
acf83's Avatar
acf83
don't take it the wrong way, i just a playin around.
Old Mar 30, 2006 | 12:58 PM
kspilkinton's Avatar
kspilkinton
So which fluid are you changing? You mentioned transmission and then talked about the transfer case.
Door code "U" is 4R70W and that's Mercon V.
Door code "E" is 4R100 and that's Mercon.
Transfer case is a BW44-06 and I'm pretty sure that's Mercon.
4R100 is only found on trucks with a 5.4. The 4R70Ws could also be found behind the 5.4s, however the 4.6s and 4.2s with autos definitely will have the 4R70W from '97-'04(Heritage).
-Kerry
Old Mar 30, 2006 | 05:24 PM
acf83's Avatar
acf83
changed both of them, i was curious as to how the transfer case would call for a different fluid, then the transmission. are they sealed (transfer & tranny)from one another? by the way the guy at the parts desk stated that depending on where your truck was manufactured depended on what tranny was struck in the truck. that didn't make much since to me.
Old Mar 31, 2006 | 03:07 AM
kspilkinton
They are sealed by seals... then there's the joint between them.
Sometimes it's a wonder parts people know what planet we're on.
-Kerry
Old Mar 31, 2006 | 09:07 AM
skilife17's Avatar
skilife17
My 97 4.6 auto 4x4 has the 4r70w and it takes mercon and not mercon V. Could it be that my truck was built in March of 96.
Old Mar 31, 2006 | 12:11 PM
kspilkinton
You know, I was thinking about that when I replied the last time, perhaps that what the parts guy was trying to say...
I believe the cutoff was the '97 or '98 model year. Problem is I've heard of trucks coming with their factory operating manuals that say Mercon and the dip stick top saying "Use Mercon V." In ACF's case (2003 model) I'm very certain the 4R70W was a Mercon V unit, though.
-Kerry
Old Mar 31, 2006 | 12:17 PM
skilife17's Avatar
skilife17
Thanx kspilkinton my manual says mercon and so does the dipstick for the tranny. I have seen a lot of posts about guys saying that the 4r70w took Mercon V. I know when my dad and I changed the filter he had to call and see what would work.
Old Mar 31, 2006 | 12:32 PM
kspilkinton
Actually I should be thanking you, if you hadn't have spoken up we could have had a few people damage their trannies by adding the wrong ATF based on this thread. We're all here to help, right?
So, thanks skilife17... I always need someone to point out when I'm wrong, just so I don't get too deep into trouble.
-Kerry
Old Mar 31, 2006 | 01:34 PM
skilife17's Avatar
skilife17
Kerry your welcome, almost made the same mistake by almost putting Mercon V in mine. Wouldn't be good using wrong fluid. That's the whole point of this site is to help each other.
-jason
AmmoDawg
Jan 8, 2013 09:26 AM
UNTAMND
18
Aug 31, 2010 11:53 AM
60RatRod
Dec 6, 2008 06:15 PM
kelro
Oil & Lubrication
May 28, 2005 11:50 AM
bobcity
Oil & Lubrication
Apr 20, 2005 08:38 PM
