Silicone brake fluid
Old Jun 10, 2001 | 05:55 PM
6t6merc's Avatar
6t6merc
I thought I should make the change since I have the system apart and so I don't ruin my new paint. Does anyone have experience with this job?
Eric
Old Jun 11, 2001 | 10:02 AM
jbhf250's Avatar
jbhf250
i thought about doing the same thing last year when i rebuilt my brakes...Disc in front ..drum in back. As I remember silicone would be OK in a Brand New system not one that is `contaminated` with DOT type fluid. Sorry I cant remember exactly why
I settled with just flushing out the system and using DOT 4 fluid.
__JOHN__Õ¿ö
FTE Club #7
Member-
http://www.cruisin-north.com/
Santa Rosa, Calif.
72 F-250
ICQ#6030753
http://www.ford-trucks.net/users/jbhf250/
https://www.ford-trucks.com/pictorial/big/1972_f250_2.html
Old Jun 11, 2001 | 10:58 AM
skip4274's Avatar
skip4274
The problem with standard brake fluid, Dot 3 and 4, is that is absorbs moisture from the minute you open the can. You need to throw away the leftovers once you open it up and have finished bleeding the system.
The problem with Dot 5 silicone is that even though it is inert, it costs about $25.00 a can.
Unless you have "completely" rebuilt your brake system, new lines, hoses, cylinders etc. don't waste your money. Just go with the standard and way cheap brake fluid and plan on changing it out every year or two.
"IF" you've spent the money and rebuilt the system, the Dot 5 is well worth the money.
Skip4274
4everFord
Old Jun 11, 2001 | 11:15 AM
6t6merc's Avatar
6t6merc
Not quite everything is new - the cylinders will still have fluid in them. So, even if I flush the system with alcohol the silicone will become contaminated? I was looking forward to painting the m/cyl and being done with that paint stripping problem forever.
Eric
Old Jun 11, 2001 | 08:35 PM
skip4274's Avatar
skip4274
Use denatured alcohol to purge the system. It absorbs water. Fill the system and let it set a day or two, then pump it all out and leave everything open so it can dry out. Then run some Dot 5 through the cylinders. You should be o.k.
Skip
Old Jun 12, 2001 | 11:11 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
Old Jun 12, 2001 | 11:16 AM
6t6merc's Avatar
6t6merc
I was going to do exactly that Skip, until I saw the price of Dot 5.
Eric
F 250 6 liter
Nov 15, 2010 08:42 PM
6t6merc
May 26, 2004 04:38 PM
6t6merc
Jan 22, 2002 05:07 AM
