About these wheel studs...
Old May 26, 2004 | 10:37 AM
6t6merc's Avatar
6t6merc
Two of the eight on one rear hub have damaged threads. Can I run a die over them (in place) or do I have to remove the hub and bang them out? TIA.
Eric
Old May 26, 2004 | 11:00 AM
2ndmouse's Avatar
2ndmouse
my truck came with locked lugs on 3 wheels (one each) and no key.
I smacked em with a sledgehammer and the snapped off. (i know brutal but the air chisle wasnt working and my nerves were shot)
Poping the old studs out isnt hard, a center punch and some blaster oil and *pop*
And ya put a new stud in.
Old May 26, 2004 | 11:14 AM
6t6merc's Avatar
6t6merc
Thanks for the reply. I'm trying to avoid the r&r of the axle, hub, and seal. The problem, as I see it, is that a conventional T-handle die tool will not turn past the hub. I think I'm contemplating a tool which might resemble a die inside a deep socket. Does such a thing exist?
Eric
Old May 26, 2004 | 04:38 PM
2ndmouse's Avatar
2ndmouse
i dont know if I would trust a retapped stud....i get nerved out with patched stuff.
think of it this way, you'll know you have fresh seals and new studs.
one less thing that will need done later.
Eric Laramore
1997 - 2003 F150
Nov 22, 2013 11:12 PM
6t6merc
Apr 30, 2012 10:21 AM
05 f250 6 inch lift
Sep 1, 2011 07:28 AM
F 250 6 liter
Nov 15, 2010 08:42 PM
