water pump
Old Sep 15, 2006 | 08:31 PM
fatherheart3's Avatar
fatherheart3
water pump
How Much Does It Cost To Repair A Water Pump On A 1999 Powerstroke Dually.
Old Sep 15, 2006 | 09:31 PM
ReAX's Avatar
ReAX
A1 reman pump list for 199.45, delco pump is 421.82 for 2wd, I can't get a price on motorcraft this late in the evening.
Figure something like 2-6 hours labor, shops run from $45-85 an hour and add atleast $50 for coolant/seals, minor incidentals. I wouldn't expect a shop to cust you loose for any less than $500, more like $700.
Old Sep 16, 2006 | 06:16 AM
jetdoc's Avatar
jetdoc
I just paid $150 for a new Airtex pump. Do a search in the 7.3 forum for the install write ups.
Duncan
Edited to correct spelling. Need more coffee.
Old Sep 16, 2006 | 08:34 AM
Beast12's Avatar
Beast12
Thread moved to 99-2003 7.3L PowerStroke Diesel forum.
-Matt
Old Sep 16, 2006 | 09:28 PM
fordpowerstoke7_3's Avatar
fordpowerstoke7_3
i just bought a new one from checkers auto it costed me $176 i installed myself though
Old Sep 16, 2006 | 09:42 PM
wlihntr's Avatar
wlihntr
got a reman for $110.00 at napa. did it a weak or so ago pretty straight foward RR except fo getting the fan/clutch off and back on. i clamped a C-clamp to the top of the waterpump pulley than used a pipe wrench to get it off. when the C-camp contacted the housing for the hearter hose outlet it held it in place to get the fan/clutch bolt lose, when putting it back there is not much room to work (the fan shroud and fan have to come out and go back in together) you have to get the threads lined up just right for it to grab..be patient it may take some time
Old Sep 16, 2006 | 10:56 PM
powrstrkn''s Avatar
powrstrkn'
If you do decide to do the job yourself remember not to overtighten the bolts they only need to be torqued to 17 ft lbs or so.
I think that there is a thread on the waterpump in the readfirst/common mod sticky on the main page
Old Sep 18, 2006 | 09:40 AM
fatherheart3
Water Pump
Thank You Very Much For The Info..taking It In This Am To Get Fixed...
arcticatdan
Jan 31, 2014 10:04 AM
dell
Feb 20, 2006 08:01 AM
beartracks
22
Sep 2, 2004 10:35 AM
mtflat
Jan 19, 2002 09:51 PM
