Emergency flasher??
Old Jun 23, 2001 | 09:05 PM
oldford64's Avatar
oldford64
Emergency flasher??
Did 1964 standard cab trucks have an emergency flasher? My 64 standard does. It is a ford one as it says "FoMoCo". Hanging underneath the dash is a working red light flasher that i remember seeing in a 66 on the dash. My 64 has no holes cut in the dash for it. I'm thinking that someone may have put one from a 66 in my truck sometime after my truck was made. Can anyone help?
Travis
1964 f100 SWB stepside
1965 f100 LWB styleside
http://www.geocities.com/oldford65
check out the Slick 60's ford truck club for 1961-1966 ford trucks......
http://clubs.yahoo.com/clubs/fordpickups61to66fseries
Old Jun 25, 2001 | 07:50 PM
66ranger's Avatar
66ranger
Emergency flasher??
In 1964, the ICC 4-way flasher was an $11.60 option. Flashers tell an interesting story. They seem to have been a regular option until '65. Then they were shipped on every 65/66 truck automaticly UNLESS a "Delete" option was selected. My '66 F101 was a delete model; but I have since put this "option" into it. An interesting twist was that the under dash bracket that said "Emergency Flasher" on it was part of the kit. I had another '66 Camp Special truck. It had the normal flasher & light installed in the dash. But when it was taken apart, the under dash bracket was mounted to the flasher behind the dash, just like it would of been if it was an under dash add-on. Apparently, someone on the assembly line didn't know this bracket was not needed. Connectors were still factory striped, so I know it was shipped that way. If you pull a flasher from a parts truck, get the entire related wire harness. It just snaps in place, after the 2 dash holes are drilled of course!
Old Jun 26, 2001 | 12:21 PM
65fordf100's Avatar
65fordf100
Emergency flasher??
ktnissen
41
Dec 13, 2022 09:31 AM
DBSGarage
15
Jul 27, 2015 08:48 PM
ruschracing4
Feb 4, 2015 09:50 AM
mosigndude
Dec 22, 2014 09:06 AM
