66 Ford F100 4x4 Dash Knobs CC-352-SWB
Old Dec 21, 2014 | 03:36 PM
mosigndude's Avatar
mosigndude
66 Ford F100 4x4 Dash ***** CC-352-SWB
I am needing information about the dash controls for my Custom Cab.....with those to the right of the steering wheel I have four accessory *****......from left to right they are: 1) the Emergency Warning Flasher (red light lense); 2) the Emergency Flasher switch; 3) the Choke and; 4) the Fan Off Hi/Lo (Pull for DEF).
My question on my Emergency Flasher (EF) switch bezel is about the bezel being blank (no lettering).......I only see in the reproduction parts books that for '68 and above having bezels marked with "Emergency Flasher"......my question is, since all of the other dash **** bezels have **** function lettering, shouldn't this one?
I suspect the bezel I have has been replaced and is not what would have been "as built"....the EF had to be, IMO, an ordered option on this truck as all of the wiring is integral to the primary dash wiring harness (I have several NOS EF wiring harnesses that would have been add-on I suspect as they are stand alone harnesses).
Additionally, on the left I had a "Blink Marker Light" push button (momentary) switch that allows the operator to push and (essentially) break the power to the cab marker lights, thus blinking them if the switch is pushed and released.....this was cut into the dash above the ignition switch.....I have taken this out, patched the dash and will probably make this an under the dash option, I suspect the cab marker lights and this blink option were added?.....my question here is, would this blink switch have ever been an option? The bezel and switch are definitely period.
I have another question, did they place ***** in different positions based on the options originally ordered and is there a document showing all possible options that would have a dash ****?
ND, I could use availability and P/N if this Emergency Flasher bezel part exists, I would prefer NOS versus reproduction.
Thanks, m.
Old Dec 22, 2014 | 06:52 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by mosigndude
I am needing information about the dash controls for my Custom Cab.....with those to the right of the steering wheel I have four accessory *****......from left to right they are: 1) the Emergency Warning Flasher (red light lens); 2) the Emergency Flasher switch; 3) the Choke and; 4) the Fan Off Hi/Lo (Pull for DEF).
Choke **** & bezel only furnished with the cable.
My question on my Emergency Flasher (EF) switch bezel is about the bezel being blank (no lettering). I only see in the reproduction parts books that for '68 and above having bezels marked with "Emergency Flasher."
1967/69: There isn't a bezel, E/F switch mounts to a bracket, which is located on the inside of the glove box. 1970/72's have a bezel, as the switch is mounted on the dash.
***** are located in the same place as listed in your first paragraph.
C5TZ-15C580-A .. Emergency Flasher Bezel / Obsolete
1965/66 F100/250 2WD & 1966 F100 4WD
CARPENTER NOS OBSOLETE PARTS in Concord NC has 18 = 800-476-9653.
C1TF-17513-A .. ****-Wiper Switch, Heater Blower Switch & Emergency Flasher Switch / Reproduced.
Old Dec 22, 2014 | 08:54 AM
mosigndude's Avatar
mosigndude
ND - Thanks
I did get the search function to yield most of this information, you have addressed a lot of it in previous posts......is this bezel blank? m
Old Dec 22, 2014 | 08:59 AM
NumberDummy
Is this bezel blank?
Looks to be blank in parts catalog pic...and parts catalog text description (see 15C580 below) makes no mention of it being marked.
Notice that it does say that the 1970/72 bezel is.
Old Dec 22, 2014 | 09:04 AM
mosigndude's Avatar
mosigndude
Thanks Bill, one last question, were the Blink Marker Lights an option for the F100 or did someone put this in from a bigger truck? m
Old Dec 22, 2014 | 09:06 AM
NumberDummy
AFAIK 1965/66 was a factory installed option or a dealer installed accessory. Beginning 1967: Standard equipment.
AlsRyd66
23
Nov 16, 2017 08:21 AM
teched
Jul 27, 2014 11:18 AM
F600greg
Large Truck
Mar 26, 2014 02:59 AM
Car Guy
Aerostar
25
Nov 12, 2011 08:41 AM
Brock_Samson
Sep 24, 2009 08:57 PM
