CCV flack
Old Sep 14, 2006 | 07:46 PM
ron's power stroke's Avatar
ron's power stroke
lol nut. i just found some bio my way. cant wait to try it. not sure about the b rating on it though. will find out tomarrow. how low is to low to make not worth wild to travel for? how much is the bio down that way? #2 just droped to 2.87 this morning up here. im sure your probly at least 10 cent cheaper.
ryaneverk2's Avatar
ryaneverk2
I'm actually trying to decide what to do with mine... currently it's running all the way back to just before the rear bumper, but along the way there are about three low spots that are sort of tough to avoid when running the hose that far, and they're gathering small amounts of oil.
I'm going to either force one extra low spot early in the hose, and install a T there with a plug so I can drain it once in a while, or I'm going to just cut it at the bottom where it first comes down to the frame, like the T444E version, and just let it go right there. Only drawback I can see to the first one is that while it's much easier and no-maintenance, the fumes would then be under the cab rather than back at the rear bumper.... not sure if they'd bug me in the cab or not.
Old Sep 14, 2006 | 07:48 PM
clux's Avatar
clux
Crankcase ventilation systems are emissions control devices. It is illegal under the clean air act to tamper with any emission control devices.
US CODE TITLE 42 > CHAPTER 85 > SUBCHAPTER II > Part A > § 7522
PROHIBITED ACTS
(3)(A) for any person to remove or render inoperative any device or element of design installed on or in a motor vehicle or motor vehicle engine in compliance with regulations under this subchapter prior to its sale and delivery to the ultimate purchaser, or for any person knowingly to remove or render inoperative any such device or element of design after such sale and delivery to the ultimate purchaser;
I suspect the mechanic was right, that venting the CCV to air is in violation of the clean air act.
Old Sep 14, 2006 | 07:51 PM
PSNut's Avatar
PSNut
My home heating oil supplier delivered my first batch
@ 2.64/gal with 150gal min purchase. He dropped off 3 drums in my driveway. Cool ehh? I believe he'll deliver throughout NH. His site LINK
Old Sep 14, 2006 | 07:52 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Ryan, I don't think you're going to like your "Draft Tube" venting near the cab. You've smelled that stuff.
Old Sep 14, 2006 | 07:55 PM
PSNut's Avatar
PSNut
PROHIBITED ACTS
How about the T444E?
ron's power stroke
wow thanks alot nut. ill call him tomarrow.cool he delivers. cant get any better then that.not a bad price ether...
Old Sep 14, 2006 | 07:57 PM
cnd999's Avatar
cnd999
[QUOTE=ryaneverk2]Actually it wouldn't matter if he noticed you have no cat, because your truck didn't come with one from the factory. It would only be an issue if it came with a cat from the factory and then you disabled it.
Ryan, I acually did have a factory cat and trashed it when I put my 4 inch on,some of the earlys had em.
wow theres a few of us from the north county. ive herd that too. but i think it was in the international trucks. im just not sure how it is less of a pollutant going into an intake rather then a canester or an exhaust. eather way it spreads oil under the hood and vapers go out the exhaust any ways.
Ron I think the garage`s concern centered around factory installed equipment remaining intact. I can see there point, they don`t want it to come back on them.
Old Sep 14, 2006 | 07:58 PM
clux's Avatar
clux
There are different emission standards for the heavier trucks that use that version. It depends on the year of manufacture and class of vehicle. Our '91 Dodge with the Cummins also vented to atmosphere, but I'll bet they don't now.
Old Sep 14, 2006 | 08:01 PM
cnd999's Avatar
cnd999
Sorry clux ya beat me to it, Im a really slowww typer I guess
Old Sep 14, 2006 | 08:05 PM
ryaneverk2's Avatar
ryaneverk2
Yeah, but to be honest I can only really smell it if I really bend down back by the bumper and put my nose right near the hose. Just standing back there I can't really smell it. I don't think I'll be able to notice them up in the cab if the hose exits down by the tranny, but we'll see. I can always try it, then if the smell bothers me, put the T in there and rerun the hose like I planned, with the big low spot at the T so I can drain it when need-be.
Ah, thanks, didn't see you had an early 99. The little rule of thumb I was thinking of applies to 99.5+ models.
Old Sep 14, 2006 | 08:06 PM
PSNut's Avatar
PSNut
Yeah...that makes sense Clux...thanks for the heads up. Glad i'm using bio diesel.
Old Sep 14, 2006 | 10:06 PM
  #28
jtharvey's Avatar
jtharvey
Originally Posted by amiller93
You can always plug into the exhaust and hide the hose at the top of the framerail, unless they are specificall looking for it i doubt they would notice it. If you are straight piped just tap into the exhaust DP.
I would advise against putting it in the downpipe. It's the highest pressure area of the exhaust system, even in a straight piped truck. If you run it into your exhaust, you'll want to do it as close to the exit as possible, to eliminate any pressure potential. Most of the guys who run them into the exhaust will tap into the exhaust at the hump over the rear axle.
I actually just hooked mine into my exhaust today, putting it right before the T-pipe for my stacks. I just got tired of smoke coming out from under my bed. Used a kit from Jegs, ran some copper pipe, and attached my CCV hose to it. I'll get a pic uploaded here in a bit of what I did.
Old Sep 14, 2006 | 10:15 PM
  #29
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
here is my crankcase vent.
http://rides.webshots.com/photo/5522...91838520keCoHr
look for the other pics in the album for the rest of the CCV pics scattered throughout.
Old Sep 14, 2006 | 10:55 PM
  #30
jtharvey's Avatar
jtharvey
Here is how I tied mine into my exhaust, very similar to what Kris has done.
