high idle
The IAC is the Idle Air Control Valve. It's mounted on the side of the throttle body and straddles the butterflies in the throttle body. When the engine is at idle, the butterflies should be completely closed. This is where the IAC comes in. The EEC will monitor RPM, and if it drops below 672 RPM, it will open the IAC to bypass the butterflies and raise the idle back up. This is not the only job of the IAC, though. When the throttle is open, the IAC will open completely. Then, when you let the throttle snap back shut, the IAC will close off slowly, and prevent stalling due to excess vacuum in the intake. There's also some other tricks that the EEC does with timing and fuel when you take your foot off the throttle and let the vehicle coast to help slow it down. It isn't as noticeable with automatics, but you can feel the timing being changed when you gear down a manual tranny when slowing down. This helps provide braking with the engine.
Since the IAC is in close proximity to the EGR (Exhaust Gas Recirculation) valve, sometimes the back port will gum up with carbon deposits from the exhaust. The IAC can be removed and cleaned without removing the Throttle body, but I don't recommend it. If the IAC's got stuff in it, so does the throttle body, and you're only going to knock it down in the intake if you try to clean it with the TB in place. It only takes about an hour to strip it down to the lower intake, which I would recommend doing so if the plenum's never been off the engine, and it has any significant mileage on it. The gasket set will cost about $8 at Advance Auto, and trust me, it will make a HUGE difference in the idle if there are leaks between the plenum and intake.
Have a peek at my gallery, and you'll get the gist of what I'm talking about. There's one bolt that's a little bit tough to get to, but it's a T40 Torx. You'll need one that fits in a 1/4" drive socket, because a 3/8" drive socket's shoulders are too big to get the bit in the bolt. I did it without pulling the distributor, meaning I didn't have to re-time the engine. The bottom half of the housing on the dizzy came off with two bolts, and gave me plenty access. While you're in there, you should probably consider o-rings on the injectors, minimum, and if you have time, get the injectors cleaned. Don't even think about new injectors. They're about $80/injector, so you're looking at $640 for a set. You can get injector rebuild kits from mrinjector on Ebay, which include the o-rings, filters, and pintle caps. I don't remember the price, but it wasn't very expensive.
Jump in with both feet, 'cause there's lots of great help in here, and you'll learn a lot about your truck while you're working on it. Best of all, you won't be paying a bunch of monkeys a ton of money to screw it up worse than it already is. Study the job, and ask questions. That's what we're all here for.
Anyway my problems came back so I scanned and it said TPS. TPS was only a year old so I looked at the voltage and it was 1.1v. The nice people on this site said .8-.99v is where you want to be. I reset it to about .95 and so far so good. I guess it kept thinking I was hitting the gas a little...
Good luck
Il let yall know how it pans out. Thanks agin.
