View Poll Results: Why doesn't my fuel guage work
fuel guage
0%
fuel tank
100.00%
Voters: 5. You may not vote on this poll
Fuel guage problem
Old Sep 13, 2006 | 06:28 PM
halmar's Avatar
halmar
Fuel guage problem
I just put a new fuel tank in my 86 F150 with 300-6 and carb. It has duel tanks, but they were both leaking. I removed both tanks but only replaced the side tank at this time. Now the fuel guage doesn't work. I checked to make sure the plug was tight on the sending unit and it was. Does the rear tank need to be plugged in to work?
Thanks,
Mark
Old Sep 13, 2006 | 08:45 PM
Beast12's Avatar
Beast12
Hi Mark! Welcome to the site. I moved your post to the 80-86 F-series forum. Should get some help here.
Read this for some info that will help you around the site: https://www.ford-trucks.com/forums/s...92&postcount=2
-Matt
Old Sep 13, 2006 | 09:01 PM
fordfaninIL.'s Avatar
fordfaninIL.
If you replaced only the front tank then you need to have the fuel tank selector switch set to the front. The same would go for the back tank. If you have everything wired correctly, and you have the correct tank selected, then it has to be either the sending unit or the gauge.
Old Sep 14, 2006 | 08:52 AM
halmar's Avatar
halmar
Thanks, I will check the wiring again today. Eveything worked before changing the tank. Its the front or "side" tank that I am working on and it worked before I changed the tank. The switch position is in the "front" position. Could the sending unit have got stuck somehow?
Old Sep 14, 2006 | 09:02 AM
Holmesuser01's Avatar
Holmesuser01
Red face
Did you have the sending unit out, or is this a sending unit that was already in the tank you installed? You did say new. I assume you replaced the sender?
Try unplugging the sender wire at the tank and ground it with the ign switch on. Have a helper look at your gauge. If it goes to full, you have a bad sender. Dont leave it grounded any longer than necessary.
The gauge switching from tank to tank is done at the front-rear switch. Your problem is most likely at the tank area. Look at ground connections, too. They can look good, but be totally bogus.
Old Sep 14, 2006 | 10:39 AM
Sport45's Avatar
Sport45
You may also have a cracked float that has filled with gasoline and sunk. I know that's why my front tank always sets on "empty". Anyone know where to get a replacement float?
Old Sep 14, 2006 | 06:14 PM
halmar's Avatar
halmar
Thanks, I found the problem today. I looked inside the plug and one of the connections was corroded "green". I installed new pigtail and problem went away.
Thanks again,
Mark
Old Dec 5, 2006 | 03:37 PM
franko's Avatar
franko
I have the same question.
Old Dec 5, 2006 | 03:47 PM
franko's Avatar
franko
Hey sport, the local Ford garage just told me they have them for about $4.00. Might check that out.
89FordDriver
Dec 9, 2014 11:06 AM
rjaywhit
Oct 7, 2009 09:03 AM
Grey89F250
May 20, 2008 07:45 AM
300inline6
Oct 26, 2004 10:40 AM
westval
Jun 24, 2004 08:49 AM
