Odd acceleration problem
Old Dec 3, 2006 | 06:49 PM
nickmobile67's Avatar
nickmobile67
my '86 F150, EFI 302, manual transmission. Say your going down the road at 50-55 mph (other speeds too, just an example). So your cruising along and you want to accelerate to 55-60. No need to downshift, just lightly press on the gas. Well you do that, and nothing really happens. There's no smooth acceleration. After a certain point you kinda feel it kick and go, but I don't want it to kick and go, I want it to smoothly accelerate. This is without downshifting.
It really pisses me off, and I'm not about to take it to a garage so they can spend days and dollars replacing everything just because it's an old truck and they don't know what's wrong with it either.
Old Dec 3, 2006 | 07:00 PM
must-be-a-stang's Avatar
must-be-a-stang
I had a 88 Mustang that had the same problem. I replaced the clutch and all it's goodies (plate, bearing, etc) and was good as new....only cost about 140 bucks and a weekend in the drive way. Can you make it slip when you rev on the gas?
Im sure other people will chime in with a better soultion then mine. Good luck.
Old Dec 3, 2006 | 07:24 PM
nickmobile67
I really like that thinking, but I don't think the clutch is slipping. It doesn't even seem to rev up at all until you give it that little extra gas.
Old Dec 4, 2006 | 09:46 AM
daszanto's Avatar
daszanto
Tps?
Have you tried pulling codes from the computer? Sounds like it might be a bad or out-of-adjustment Throttle Position Sensor(TPS).
Old Dec 4, 2006 | 08:32 PM
NvMyWS6's Avatar
NvMyWS6
Have you changed your fuel filters recently? Make sureto change the on that sits just behind the driver seat on the frame. Its in a little black canister.
Old Dec 5, 2006 | 03:51 PM
VirginiaWiFinder's Avatar
VirginiaWiFinder
I'm going to vote TPS too. Check the manual for how to ohm one out, but you will need an analog multi-meter to do it. It might have a dead spot.
