Expedition Gears
Old Sep 12, 2006 | 07:44 PM
315X75r16ExpyEB's Avatar
315X75r16ExpyEB
Expedition Gears
hello. ok supposedly my rear end in my expy came stock with the locking rear diff. Im not exactly sure if it works becasue a while back i got it stuck in the sand, and of course it was the same old front right tire, and rear left tire buried and spinning freely. Shouldnt the other rear tire kick in if the opposite side is spinning, and if it wasnt sould i replace it? i hate getting stuck like that
thanks for all the help
Old Sep 12, 2006 | 10:45 PM
eric james's Avatar
eric james
With the rear axle off the ground, you should be able to turn one wheel and the other should turn the same direction if you have limited slip rear end.
If both wheels turn the same way but under load it doesn't work (you were stuck) it could be worn out or you need an axle service with new gear lube and friction modifier.
Old Sep 13, 2006 | 08:04 PM
FTE Herman's Avatar
FTE Herman
^Concur. Our trucks didn't come with 'locking' differentials. Only limited slips with clutches.
Old Sep 13, 2006 | 08:08 PM
MisterCMK's Avatar
MisterCMK
Its fairly easy to rebuild a trak-loc. They have kits from the ford dealership that you can replace all the clutches.
Him3000
Sep 8, 2012 09:50 PM
smashclash
Jan 30, 2011 11:51 AM
cjfishingtoday
37
May 27, 2010 12:03 AM
dangaus
31
Aug 15, 2005 04:02 PM
edward r
Offroad & 4x4
15
Feb 18, 2004 03:36 PM
