fan blower quit
Old Sep 12, 2006 | 12:31 PM
steve mulherin's Avatar
steve mulherin
fan blower quit
Blower doesn't work at any speed. Fuse is good. 12.3 volts to the connector at motor. What do I check next? I never had a blower motor go bad. How do I check ohms to see if there is a short?
Old Sep 12, 2006 | 02:00 PM
fishmanndotcom's Avatar
fishmanndotcom
check connections at the blower. also make sure all your grounds are in good condition!
-cutts-
Old Sep 12, 2006 | 02:11 PM
steve mulherin
Fan blower quit
the connection is good at motor. Should I hot wire the motor to test? How do I check ground?
Old Sep 12, 2006 | 02:21 PM
fishmanndotcom
yea you could run a stright 12V hot lead to the fan to see if it moves, if it doesnt then you dotn have to go any further
-cutts-
Old Sep 12, 2006 | 04:45 PM
scott2appy's Avatar
scott2appy
I just had to replace the blower motor on my 1997 F250. We checked all connections for power and found that the motor was bad. We plugged the new one in before we installed it to make sure that it solved the problem and it did.
Old Sep 12, 2006 | 05:51 PM
barebackjake's Avatar
barebackjake
yeah if you got power at the connector its dead. mine went out last year, like $60 and the new one damn near blew me outta the truck.
Old Sep 19, 2006 | 10:04 AM
bockusd's Avatar
bockusd
Check the resistor pack first, it is located in the engine compartment, passanger side. You will see a connector with about 4 wires going into the duct work for cab circulation. A simple check before you get into a blower motor.
db
Old Jul 11, 2009 | 10:01 AM
Roadhammer92's Avatar
Roadhammer92
How do you identify a bad resistor is if visibly burnt? or can you test it with a multimeter? Also If the A/c Blower doesnt come on would this prevent the compressor from cycling on as well? If i'm not mistaken if the blower/resistor is shot the compressor should still run but the blower won't bring any of that chilly goodness into the cab. Am I correct?
Old Jul 13, 2009 | 11:39 AM
Roadhammer92
no takers?
Old Jul 13, 2009 | 11:48 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
The resistor pack has several resistors on it and you can visually see if one is broken. In your case all of them would have to be broken.
I had a resistor go on one of my trucks, the fan would only work at a certain speed. I doubt all the resistors would break at the same time, but hey, a quick cheap check w/12v to the motor and one scerw (I think) pulls the resistors out for a quick peak. Won't cost anything but time either way.
Let us know what you find.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Jul 13, 2009 | 11:54 AM
Cuda_jim's Avatar
Cuda_jim
If you have 12v at the connector at the motor...the resistor pack is OK, the motor is shot.
dockwatson
Mar 12, 2014 08:42 AM
donp390
Jan 12, 2014 05:25 PM
clifjen
18
Nov 12, 2013 07:43 PM
drpratt
Apr 14, 2009 09:50 AM
rickm5
Aerostar
May 10, 2001 12:14 AM
