Looking to upgrade rear end
2004 F-150 Heritage 4.2L V6. I just installed the fabtech 3.5 inch spindle lift with 285/75R16 Terra Grappler Tires. (pics coming soon). I was looking to upgrade my rear end. I have the 3.31 now and was wondering if I should go up to a 3.73 or a 4.10? I do some highway driving and was thinking that a 3.73 would be best. What do you guys think?
Also I was thinking about adding an LSD and was wondering if that would fit in my stock pumpkin or if I need to up grade the whole pumpkin to a larger one?
Thanks for your help
The reason I am looking into the 4.10 is because I upgraded to 285/75R16 tires. I used the automotive calculators on this site and to get my original ratio back (3.31) I would need a 3.70 rear end. I thought about going with the 3.73 bc it is roughly the same but figured I could use a little more low end than I had stock so thats why I went up to the 4.10 Do you know if the LSD unit will fit in the stock rear end housing?
Any opinions welcome on either the 3.73 or 4.10
erics79
10-15-2002 08:30 PM
