Steering swap
Old Sep 11, 2006 | 11:54 AM
nsaikia's Avatar
nsaikia
Steering swap
Is it possible to swap out the entire front steering component with a later model - one having ball joint and rack and pinion steering?
I am still not satisfied the way my truck handles. I had a suspension shop replace the king pins and I installed a new power steering unit and the coupler. I was wondering if I can use the whole front part of a later model truck.
I will appreciate any aftermark units I can use. I do not want to lower the truck - keep it at stock height.
Truck is 1979 F100 - 2wd.
Old Sep 12, 2006 | 03:43 AM
Torque1st's Avatar
Torque1st
Posting Legend
Have you replaced the radius arm and pivot bushings?
By coupler do you mean the rag joint?
The TIB system will never handle very well.
Old Sep 12, 2006 | 11:48 AM
nsaikia's Avatar
nsaikia
Yes, I think they replaced the radius arm. If I remember right, they mentioned that the bushings looked good. Yes, I mean the rag joint when I said coupler.
By TIB are you referring to the current system I have? Yes, it does not handle very good. So, was wondering if it can be upgraded. Of course, I do not want it to cost me an arm and a leg. I have advertisement of Mustang systems - says it is from hub to hub. Can those fit into my truck and yet maintain the stock height? I was thinking that if a newer truck (maybe 1990s) system will fit, it would be cheaper (other than labor).
Old Sep 12, 2006 | 06:38 PM
SRD4X4's Avatar
SRD4X4
96-older is basically the same thing you have now.You can go withn a complete front sub-frame i.e.Mustang II (aftermarket or fabricate yourself) or a sub-frame cut from something else (Dodge Mirada,Camaro,Ltd,etc.) the cost you save in parts will be made up in labor,though.
Old Sep 13, 2006 | 11:39 AM
nsaikia's Avatar
nsaikia
Shoot ! did not realize 96-older is still the king pin I-beam design !
When you say sub-frame, do you mean the whole front portion of the frame will have to be cut off and the aftermarket be welded on? Sorry, I have limited knowledge on this and would appreciate some education.
Old Sep 13, 2006 | 03:46 PM
SRD4X4's Avatar
SRD4X4
96-older is still twin I-beam,but with balljoints (mid 81 was last yr. for kingpins in F-100-150's).As for the sub-frame,Yep! Cut and weld.There's alot of Co.'s that make complete kits Fat Man fabrications,Heidts,JPL,Zig's,etc.But I don't know if they have any for your yr.
graphicjunkie
Mar 24, 2014 12:04 AM
shroomopolis
21
Aug 12, 2011 07:20 AM
F350moneypit
33
Jun 9, 2009 09:06 AM
doc840492
Oct 27, 2006 02:51 PM
Paul_no
Jul 14, 2002 11:46 PM
