starter issue
Old Sep 11, 2006 | 07:22 AM
kilog55's Avatar
kilog55
starter issue
starter relay clicks when you turn the key, just one click every time you turn the key. i put a new relay on and same thing happens. i am guessing the starter is shot we banged it with a hammer and it didnt free it up. and hooked the positive jumper directly to the terminal wire on the starter and it didnt spin it over either.
i have dual batteries which i believe are hooked up wrong there is a cross-over cable connected to both positives, and then the ground on the block for each battery. so basically it is a jumper wire for the pos.
i dont have a voltmeter so i cant check if there is power running to the other wire on the starter.
any ideas? need more info?
Old Sep 11, 2006 | 10:09 AM
subford's Avatar
subford
If you used a jumper cable here then I would say you have a bad starter
This should work OK for a 1979 F250 400.
any ideas?
Get a test light.
Old Sep 11, 2006 | 10:19 AM
tjc transport's Avatar
tjc transport
i ain't rite
this is the proper way to do a dual battery setup. if it was hooked pos of battery 1 to the solenoid, neg of battery 1 to pos of battery 2, and neg of battery 2 to ground, you would be putting 24 volts through the system.
unless of course you are using 6 volt batteries.
Old Sep 11, 2006 | 10:45 AM
Franklin2's Avatar
Franklin2
Make sure the batteries are good like was mentioned with a testlight or preferrably a voltmeter. Test them when the key is turned, not just sitting there with no load.
Old Sep 11, 2006 | 01:31 PM
kilog55's Avatar
kilog55
i know the one is good a friend tested it. they are both marine starting batteries 700mca each.
is it worth the extra money for a high torque starter? cause sometimes it seems if it would just crank a little faster it would start. cause they are only like $170-200.
Old Sep 12, 2006 | 12:43 PM
Franklin2's Avatar
Franklin2
Marine batteries are not as good for starting as a regular car battery. You will actually get more cranking amps out of a car battery.
No matter if you feel the battery is good or not, getting a meter and doing some voltage measurements will help you find the problem. If one battery is bad, it can pull the good one down to where it will not work either.
Old Sep 12, 2006 | 06:36 PM
kilog55's Avatar
kilog55
well ill have to upgrade to some good batteries then.
i diid pick up a starter today and after a little cranking she fired up so it was definatly the starter. and this one has a lifetime replacement so if it lasts another 27 years ill be happy. it is a reman unit so hopefully it will last for awhile.
i need to get it timed cause i think it is out of whack ometimes i get flames out the carb, plus i know the carb is too big for the motor 400 with a 750cfm edelbrock and intake. not cammed or worked as far as i know.
Old Sep 12, 2006 | 07:05 PM
Franklin2's Avatar
Franklin2
If the motor is cold, it will do that. If your intake manifold is the open single plane type, it will tend to do that too. The dual plane with the divider down the middle helps get rid of it. And yes, definitely check the timing.
Old Sep 12, 2006 | 08:39 PM
kilog55's Avatar
kilog55
yeah it diesels over a bit every now and then as well. so i am gonna get my own timing gun and also a voltmeter in the near future. plus i ahve a small vacuum leak i cant seem to locate the exact spot but it is on the intake.
i sprayed ether around the intake mating surface and it changes the idle a bit.
Old Sep 12, 2006 | 09:46 PM
Franklin2's Avatar
Franklin2
The dieseling can be helped by turning down the idle speed. Of course if you have a vacuum leak, this may be hard to do until you find that.
