94 B4000 Wiper problems
Old Sep 10, 2006 | 03:32 PM
rodymartin's Avatar
rodymartin
Question 94 B4000 Wiper problems
Well I have the Tranny fixed and the MAF changed. Now the wipers will not work on low intermittent or park. Anyone have any ideas?
I think it is the Control Module butam not sure. If it is is there a way to wire around it for low and park? Living in WA with out wipers is not a option.
<!--IBF.ATTACHMENT_419537--><!-- THE POST -->
Old Sep 10, 2006 | 03:42 PM
Bob Ayers's Avatar
Bob Ayers
The problem is the "return to rest" contacts in the motor assembly. Try cleaning and/or adjusting these contacts.
Old Sep 10, 2006 | 04:18 PM
rodymartin's Avatar
rodymartin
Woops I forgot ot mention that the wiper motor is new.
Old Sep 10, 2006 | 04:27 PM
Bob Ayers's Avatar
Bob Ayers
Ok, the next thing to check is to see if there is 12V going to the "return to rest" contacts. There should be 12V there as long as the ignition switch is on, irregardless of the wiper switch position.
Old Sep 11, 2006 | 02:58 PM
rodymartin's Avatar
rodymartin
I have the problem figured out. With my trusty manual and electrical drawings I went digging today. Found the control module after taking dash apart. I took out the module and tested the wiring. It parks and low speed works just fine if I jumper the right wires. Took out the drawings and got to looking at the module. I could not resist had to take it apart. I guess the electical schooling and working with eletronics does pay off some times. Well I looked at the cheap A$$ board they made for the intermitant setup . It is just a RC curcuit not even high tech nothing to burn out. the only thing that can cause the problem is the relay on te board. I called Ford to get a price to a replacement $102 + tax. The components in this board cost about $1 wholesale. How is that for mark up.
Old Sep 14, 2006 | 10:02 AM
rodymartin's Avatar
rodymartin
Found one for $3 at a wrecking yard. Also found a K&N filter for $3. Very good day
Old Sep 24, 2006 | 08:10 AM
wflo217919's Avatar
wflo217919
intermitten wiper governor 1992 ranger
So, where is this part located???
jbgilmour06
1997 - 2003 F150
Mar 11, 2013 07:22 PM
eraser5
Nov 17, 2010 05:34 PM
HareBall
Sep 5, 2007 08:22 AM
mechmagcn
Mar 16, 2007 12:57 AM
jbennyh
Dec 27, 2003 10:01 PM
