redline diesel catalyst
Old 09-09-2006, 06:25 PM
gopedoligist's Avatar
gopedoligist
gopedoligist is offline
hey guys, just wondering if anyone has tried the redline diesel catalyst? i was reading there add in diesel power magazine and it looked like a good product. especially with the new ulsd comming out soon.
thanks alot
geoff
Old 09-09-2006, 08:53 PM
Nitrous's Avatar
Nitrous
Nitrous is offline
I started using Redline about a month ago. What I have noticed the most is that the idle got a lot quieter. I use half a bottle per tank.
Old 09-09-2006, 11:42 PM
gopedoligist
cool, thanks alot for the quick reply.
anyone else?
Old 09-09-2006, 11:47 PM
NHRstein's Avatar
NHRstein
NHRstein is offline
all this talk about usld, it seems the only two things you loose are lubricity and btu's in the fuel, why not just add a quart of straight 30W dino oil to the tank at fill-up?
//John
Old 09-09-2006, 11:50 PM
gopedoligist
stein, thats why i was asking. because there add said it was a good fuel additive to replace lubricity.
Old 09-09-2006, 11:52 PM
NHRstein's Avatar
NHRstein
NHRstein is offline
I know this sounds weird, but in my manual it says that this vehicle will run on usld. I find it comforting, but how much testing did ford do to come to that conclusion. personally I use diesel kleen and marvel mystery oil as additives.
Old 09-10-2006, 12:04 AM
Beachbumcook's Avatar
Beachbumcook
Beachbumcook is offline
Got Diesel?
//John
Because motor oil is not meant to be burned in the combustion process, it will clog your fuel filters and it will clog your injectors. For what we pay for these trucks, why would anyone suggest such? Read you manual... it says not do it and this is so "old school".
Use a name brand fuel additive (with no alcohol) and enjoy.
Old 09-10-2006, 12:15 AM
bczolone's Avatar
bczolone
bczolone is offline
I use diesel kleen and red line now and alternate between fillups (1 bottle) for about 75gal is what I use (w/aux tank) and I'm going to try ford's stuff if you can still get it??? can you? I found recently that a lot of places are out...something about the new fuel laws?...I still have some left...anyways I do it because I hope that its keeping my EGR clean...other than that I have noticed NO difference in milage or anything else.
Old 09-10-2006, 11:03 AM
diesel_dan's Avatar
diesel_dan
diesel_dan is offline
I've used the Redline Fuel Catylist for years in an older diesel on my Bobcat -- never had a fuel related issue (I don't think that fuel system could even handle the 500ppm LSD w/o it). I only mix it at their maintenance rate... Haven't put anything in the new truck's fuel tank other than what comes out of the pump. Last fillup was with ULSD....
Gopedoligist: If you're in the Bay Area and have filled up since 9/2, you're already running ULSD!
Old 09-11-2006, 12:24 PM
gopedoligist
dieseldan, wow, i was looking for the release date of ulsd but could not find it on this site. thanks for the info, ill be getting some redline or diesel kleen before my next fill up. thanks again everyone
Major Marvin
13
01-07-2012 03:48 PM
matthew35
10-17-2006 12:07 PM
Moby Dick
Bio-diesel, Propane & Alternative Diesel Engine Fuels
10-13-2006 09:38 AM
7FORD2
26
04-05-2006 09:29 PM
eco
01-28-2006 10:03 AM
Quick Reply: redline diesel catalyst
