lost power
Old Sep 10, 2006 | 10:48 AM
katdon2001's Avatar
katdon2001
lost power
This ones got me truck is a 85 f250 w/6.9 diesel
a nail got droped into the cig lighter while my hired man was getting some out of the box .He said he heard the cig lighter arc and pulled the nail out.Then when they left the job he noticed no power to dash lights, horn, glow plug light assy,pyrometer gage lite
Checked the fuses related to the above mentioned all
look good no smoked or burnt fuse i have full electrical schematics and still cannot find the problem
need to get this old work horse back on the job
Thanks for helping
Old Sep 10, 2006 | 12:26 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Check the fuses with a test light, I have seen many blow that were not visable to the eye.
Old Sep 10, 2006 | 01:53 PM
KJLYPW's Avatar
KJLYPW
Often the main power wire(s) to the distribution box will be protected by fuseable links, which is a section of color coded wire, with a terminal eye that has a narrow section of wire designed to burn up and will blister the insulation, rather than fry the entire electrical system. Check for a burnt or blistered section of wire right at the main power soliniod after the positive post of the battery.
Old Sep 10, 2006 | 04:06 PM
katdon2001's Avatar
katdon2001
Dave,do you mean test the fuse itself with test lite? if so how?.....or, in the fuse box for that particular fuse?
I also checked for burnt fuse/link by the battery as was also kindly suggested and saw nothing looking as tho it fried, yet.. thanks
Old Sep 10, 2006 | 06:02 PM
Dave Sponaugle
I would check both the fues panel and the fuse with a test light.
If you have no power on either termial of the fuse box, then the fuse has nothing to do with it.
Everything you listed other than the lighter is a light.
I am wondering if the power surge toasted the light switch dash lights dimmer.
kengarchow
Jul 1, 2014 12:42 PM
Icicle
May 30, 2014 02:37 PM
sanders46
May 3, 2011 07:09 PM
clhart426
Sep 7, 2010 08:44 PM
Boltgunner
Electrical Systems/Wiring
May 23, 2004 04:53 PM
