im been looking at different trucks lately and found some that have the c6 trans instead of the e40d. i would like to know how much of a difference in mileage it would make behind a 7.3 non turbo.
That depends a lot on how you will drive it.
The C 6 is a direct drive transmission.
The E4OD is an overdrive transmission.
So if you intend to do a lot of driving at interstate speeds the MPG impact will be 6 or 7 MPG.
Something else to consider, the C6 is bulletproof compared to the E4OD.
E4OD rebuilds are in the 3 to 4 thousand dollar range.
Diesel fuel mileage is a hard thing to predict, so much of it depends on how you drive, what you haul or tow and what type of terrain you live in.
I have the same truck, and 88 and everything. Mine has a C6 and got 10 mpg avg everytime until I put a GearVendors Overdrive which basically makes it act like an E4OD, so now it gets about 14 mpg. Gear vendors is not something that is normally financially worthwhile, unless you take one off something else, like i did.
when my 88 had the zf5 speed in it, i averaged 19-23 on the road, and 15-19 around town. this was with the turbo, 35 inch tires, and 4.10 gears.
after i put the C/6 in it, mileage around town went down to 9-12, but it seems to always be loaded to the max, or towing 7-8 tons. i have not taken it on a road trip with the C/6, i have the crown vic for long runs.
not with the C/6. the C/6 does not have a locking torque converter, so you can not determine rpm verses speed like you do with a manual trans.
that sounds about rite with stock tires. with the 36's i have on mine, 3000 is about 72 mph
you sorta can relate speed and rpm on a c6, vaguely. when i had a c6, the rpm were 200-300 above what a direct drive manual should be. he gave me a range of 3000-3200 rpms at 65mph, it also has an ATS torque convertor so that should be tighter(less slippage) than a stock one.
